When does the Slim Fan on an aftermarket turbo kit turn on??
Hi guys-
I finally got my car back up and running today and the bay was very hot and I never once heard my slim fan kick on (driver's side on radiator).. When do these kick on? The passenger side one didn't either, but that one is only for when the AC is on, correct? It cool the condenser, right? Thanks guys!!!
I wondered the same thing when I installed mine. I can't hear it turn on.
I pulled over and let it idle for a few minutes, it turns on and off though. I really don't know how it works or what triggers it.
You should have wired the slim fan in by splicing into the factory fan's wiring harness. Therefore, it should turn on at the same time the factory fan did. As stated above, it should turn on depending upon the vehicles coolant temp.
This is exactly what i did.. and I know the wires cant be interchanged considering the stock are the same colors as the ones off of my slim fan.. I logged the car and it is reaching about 220 degrees (coolant temperature) and still have yet to hear it kick on.. My tuner said that it would probably kick on if I had the AC on, but my AC isn't hooked up right now so I can't really test that.. :/
Hi guys-
I have also replaced my stock fan with a slimfan. I am now having an issue with the secondary fan located in the fron of the radiator on the passenger side. Does anyone know how to test that one? Is when the AC is turned on? because it does not. How does that connect to the fan module? Anyone know where the wiring goes? Lastly is this something a tune can defeat by accident?
How would I go about using Evoscan to activate them, any help is appreciated sir, thank you!
Okay, I did this and the passenger side fan (in front of AC condenser) came out but the slim fan did not.. I'm wondering if my stock fan control box might be bad? Do you have an aftermarket slim fan? There is 3 plugs on the stock fan control box, but i am only using 2 (i think from what I remember, the stock fan plugs into one of the ports, so i wouldn't use it now).. any ideas? and is that actuator thing in evoscan supposed to turn on the driver's side fan on the radiator or just the passenger side fan or both? thanks!
