Fuel shuts off when turbo goes into boost.
Old Aug 25, 2009 | 06:48 PM
krypt952's Avatar
O was driving home yesterday on the freeway, all of a sudden the car will not go into boost, it gets up to about 4000 RPMS then I hear a sucking noise like a vacume hose and then the car starts jerking violently (I think its because the fuel is shutting off) and i have to upshift, when I rev up the car in nutral it does not do this but only when im driving, I was thinking it was a loose vacume hose or maby a bad boost leake,
thanks for all your help
Aaron
Old Aug 25, 2009 | 07:37 PM
DragEvo9's Avatar
big problem..
Old Aug 25, 2009 | 07:41 PM
krypt952's Avatar
I dont think so because before it was doing this when I did not hae the hose that goes from the intake to a vaccume selanoide
Old Aug 25, 2009 | 07:46 PM
FedEvo8's Avatar
Yeah, do a boost leak check, sounds like you have a leak somewhere. Might also want to check your plugs.
Old Aug 25, 2009 | 07:50 PM
wevo1985's Avatar
sounds like a big boost leak, how does the car idle? i had this happen once when a cuppler came half off and would only leak at about 5 or 6 psi. car idled good and all.
Old Aug 25, 2009 | 07:58 PM
xmaciek82x's Avatar
Do you have a boost guage? How does your vacuum look?
Old Aug 25, 2009 | 08:09 PM
krypt952's Avatar
its sitting at idol about 55 CM/HG on the stock MR gauges, when i push the gas it goes to about 65cm/hg cm/hg then starts to go towards boost, and the car idols perfect nothing is wrong even when I rev it in out of gear it sounds good, its only when im driving it.
Old Aug 25, 2009 | 08:23 PM
wtbEVO9's Avatar
have you done anything to your fuel pump recently?
Old Aug 25, 2009 | 08:25 PM
krypt952's Avatar
nope stock fuel pump, it was working PERFECT , drove it down to the beach, drove it home and on the freeway out of nowhere it started acting all crazy, i was thinking maby i had got on it and it blew loose a hose or something
Evoleader88
Mar 26, 2011 08:50 PM
evillancer06
Mar 13, 2008 07:00 PM
bluebyu36
Dec 23, 2006 06:42 PM
o4whtevors
Apr 1, 2005 12:09 AM
mitsuorder
Mar 21, 2004 02:24 PM
