Mandrel Bend vs Press Bend?
Old Aug 31, 2009 | 04:43 PM
Babs's Avatar
so i'm probably getting a new exhaust and i'm going to be using the buschur bullet muffler so i need a midpipe of some sort.
i know press benders crimp the exhaust at the bend but how much difference does it really make? how small of a diameter does the piping get crimped down to (if it's 3'' piping)? how much would it hurt the car performance-wise?
thanks in advance
Old Aug 31, 2009 | 05:35 PM
Fairclough's Avatar
Air flows like water (it swirls around the outside diameter) like when you drain the bath tub it rotates around the perimeter of the drain. When you use anything but mandrel bent tubing it will hurt the flow and build pressure. Try to use weld els, www.burnsstainless.com
Old Aug 31, 2009 | 05:48 PM
GaBe511's Avatar
I agree, if it isn't a smooth flow, the 3inch diameter won't really make a difference.
Old Aug 31, 2009 | 06:03 PM
Kracka's Avatar
Hurts flow and sound quality quite a bit. I'd take a mandrel 2.5" over a press 3".
Old Aug 31, 2009 | 06:05 PM
Babs's Avatar
question about the burns piping...how will i exactly know how long of piping will i need and what degree bends? i don't want to buy piping to find out that it's not long enough or not angled enough, etc...
has anybody made an exhaust out of burns and remember exactly what they bought for it?
also, burns uses OD. so would a 3 1/4'' OD equate to 3" ID?
thanks
Old Aug 31, 2009 | 06:07 PM
bluebanana23's Avatar
Smooth mandrel bends are somewhat more important than size up to a point. Mandrel 2.5" should be a better exhaust than a crush bent 3" pipe. Do it right the first time.
Old Aug 31, 2009 | 06:11 PM
denver's Avatar
most exhaust are already based on OD. So get about a .063 to an .089 wall thickness.
As for what to get... I do not know... I would think about 10 to 15ft of straight and 2-45* bends should about do it....
I personally use these guys:
http://www.mandrel-bends.com/catalog...r-kit-916.html
Old Aug 31, 2009 | 06:15 PM
Babs's Avatar
10-15 ft of straight??????
not sure if i clarified it but i already have a dp and tp...i just need the midpipe to mount to a buschur bullet muffler
think 5ft will be enough in that case?
thanks for the advice
Old Sep 1, 2009 | 01:12 AM
Spinitch's Avatar
Get a WORKS mid pipe then fabricate the axle back portion
Old Sep 1, 2009 | 04:10 AM
Babs's Avatar
i dunno...$450 and it follows the same path as the stock midpipe
i think i'm better of custom...thanks though
so does anybody else know how many ft of straight, etc i should be getting?
thanks
Old Sep 1, 2009 | 04:16 AM
Craig King's Avatar
thanks
If wall thickness is .125, then yes. But that would be awfully thick.
Old Sep 1, 2009 | 07:16 AM
denver's Avatar
Yeah my bad... I was thinkinking full exhaust......
That kit I posted originally would be more than enough for what you are talking about making and the price is pretty good too....
Old Sep 1, 2009 | 07:41 AM
Babs's Avatar
thanks again for the help...i'm not too keen on buying way more than i need but i used the same website you gave me and found these (same website but they throw their stuff up on ebay too)
http://cgi.ebay.com/ebaymotors/3-00-...d=p3911.c0.m14
http://cgi.ebay.com/ebaymotors/3-00-...Q5fAccessories
so would 2 45 degree bends and 5ft of straight do the job? take into consideration it's mated to a bullet muffler too
thanks for all the help guys
Old Sep 2, 2009 | 08:21 AM
GaBe511's Avatar
Just take your midpipe off and measure it. That way you can find the length and what bends you need. And you will have just enough material.
Old Sep 2, 2009 | 09:19 AM
denver's Avatar
I try and remember to lay under my car tonight and look at mine. maybe even measure a little
TurboTravis
Nov 27, 2011 05:41 PM
ONALL4S
Jan 27, 2009 06:17 PM
dubbleugly01
Apr 30, 2006 07:55 AM
Biggwill91183
Apr 25, 2005 02:38 PM
