Noise coming from BR double pumper???
Yesterday I heard a whining type of noise coming from the double pumper, its a constant noise at idle and I've never noticed it before. does anyone know if this is a normal sound of somthing going bad with it? also I've had the system for 3 weeks, thanks!
walbro's are known to whine.. but if you just now noticed it, then i would further investigate the pumps. if one of the pumps is failing, it will be sure to effect your a/f , logs, etc.. if you're not knocking and your afr hasnt changed then I wouldn't worry.
ok thanks, I watch my AEM wb all the time and it doesnt look lean at all so maybe its done it all along but I just noticed the sound, someone told me that ur suppose to keep a 1/4 tank or more at all times with a walbro fuel pump?
That's true. The electric pump is cooled by the gas around it. A mechanic friend of mine told me that 90% of the pumps he sees fail happen in the hot part of the summer, with people letting their gas get very low and the pump gets too hot and fails...
Thanks for the replies! I really hope it's not going bad already, not even a month old! How would I go about checking it to make sure it's working properly? Other than the wb gauge
FS[Northeast]: New Buschur Racing double pumper
nismo3183
Aug 22, 2015 02:50 PM
420a-t
18
Dec 19, 2012 12:54 PM
David Buschur
60
Aug 31, 2010 06:43 PM
