Rate MY build
Old Sep 6, 2009 | 10:12 PM
Tonba's Avatar
Rate MY build
Howdy All!
Im currently about to begin my rebuild. The car is used on the street, but when it is rebuild, it will be mainly focussed around Time Attack, Circuit, winding roads and a little bit of street.
Just looking for a little bit of feed back on what you guys think.
It will be run on 98 RON only. No E85 available, and I have no intention to run water/meth injection yet.
Under The Hood
Engine: Race Spec Blueprinted & Fully Rebuilt Bottom End, 2.3L Crank, Carrillo Rods w/ WMC Bolts, Forged CP Pistons, Tomei Crank Scraper & Baffle plates, ARP main & head studs, Balance Shafts Removed, IS Motor Racing Race Spec Port/Poished Head w/ Kiggly Racing Hardened Spring Seats, Ti Retainers, Kiggly Valve Springs, Ferrea Bronze Valve Guides, Ferrea Valve Locks, 1mm Oversize Nitrided Supertech Valves, Fidanza Adjustable Cam Gears, Kelford TX272 Cams.
Induction: Custom Aluminium Apexi Style Airbox, Apexi Podfilter Kit, Trust M-Spec Intercooler, Trust T67 Turbo Kit.
Injection/Fueling: Walbro 255l/hr Intank Fuel Pump, FIC 1050cc Injectors.
Ignition: SUN Auto Hot-Earth Kit, SUN Auto Voltage Stabiliser Kit, NGK Ignition Leads.
Engine Management: Haltech PnP Platnum Sport 2000 ECU, HKS EVC 6 LTD ED (Amber)
Exhaust: Trust Dump Pipe & Front Pipe, Custom 3.5" MIL.SPEC Metallic Cat Converter, Custom 3" Stainless Steel Catback Exhaust System.
Driveline
Gearbox: Standard 6-speed manual.
Clutch: ORC 550ps Twin Plate Race Clutch
Differential: Standard.
Brakes: Standard Brembo Calipers & Rotors, Project Mu HC+ Front Brake Pads. (If money permits, I would like a set of AP Racing Brakes)
Chassis, Suspension
HKS Kansai Front & Rear Strut Braces, Carbing Lower H Brace, Cusco Trunk Bracing, Tein Monoflex (9kg / 7kg).
Old Sep 6, 2009 | 11:40 PM
BLKCarbonEVO's Avatar
zero jk nice build though I would have done a few things different
Old Sep 7, 2009 | 04:59 AM
JakeTheVIII's Avatar
The 6 speed will a limitation eventually, you'll probably want the 5spd at some point. I'd go a different route with the ignition, Like a COP system. Sparktech, Spoolinuptuning, etc.
The motor plan looks good, I'd probly go a different turbo also if you've got the money. FP Red, 6262, HTA35R, something like that.
Old Sep 7, 2009 | 05:29 AM
Ted B's Avatar
Agreed on the comments regarding ignition and turbo.
Forget the ignition trinkets - apply the money toward a COP setup.
Get a better turbo - one that delivers performance representative of 2009, not 2004.
Start saving for a built 5-speed tranny and strengthened T-case.
Old Sep 7, 2009 | 05:34 AM
meat_EVO's Avatar
if you need to keep that jdm bling, go with the trust kit. if you prefer a performance over brand, get something besides a trust kit. FP FTW.
Old Sep 7, 2009 | 05:35 AM
+1 for getting rid of the pos 6speed!
I don't agree with your turbo choices. He said he will be autoxing/time attack... You want a turbo that spools quickly and produces a strong power band (neither of your choices: Red, 6262, or HTA35R wouldn't spool quickly and the OP wouldn't be happy with that). I would recommend going with one of the following mild-wild: Stock IX ported turbo, FP White, BBK Lite, BBK Full, HTA3076, or HTA Green.
Personally with the built 2.3L I would go HTA Green with high compression. That turbo should then spool like a stock IX but capable of 500hp/500tq.
Old Sep 7, 2009 | 09:16 PM
Tonba's Avatar
^ thanks for all your input guys.
All the items that are on the list, I already have, bar the clutch, still gotta buy that!
Just a few things;
-The turbo. Yes there are alot better choices out there. But we seem to be getting good results with this turbo, and I also got it for a price I could not refuse..
-With the ignition, Im currently saving for a CDI COP ignition system.
-Yes, I do have the garbage 6-speed. Im just going to have to look after it for now, as I dont have enough for the Evo 9 RS 5-speed with Ralliart Front LSD that I want..
The aim for it is to have the 5-speed + CDI setup and if money permits, a twin scroll turbo of some description, but I have ALOT more important things to get before I look at the transmission and turbo.
Old Sep 7, 2009 | 09:29 PM
dave_evolvix's Avatar
Originally Posted by Tonba
... but I have ALOT more important things to get before I look at the transmission and turbo.
I'm going to have to ask, whats more important to a build than Tranny and Turbo? Its the heart of your powertrain if you ask me.
Also what Tire/Wheel Size combo are you running for Time Attack?
Silly gripes aside. Sick build. Do it how you want it!
And don't forget some pics and a dyno sheet for the followup!
Old Sep 8, 2009 | 02:40 AM
Tonba's Avatar
Well, suspension, brakes, ignition to name a few.
Im running 17*9" +30 wheels with 255/40R17 Bridgestone RE55S Semi-Slicks..
Old Sep 8, 2009 | 03:14 AM
tscompusa2's Avatar
hta green or fp red for turbo.... 2.3L will rape both turbos spooling it up No need to rev out to 8k on stroker either.
Old Sep 8, 2009 | 01:29 PM
801bmx's Avatar
great build!
Old Sep 8, 2009 | 01:35 PM
scumrat's Avatar
nice build! ill trade you my 5-speed for your 6-speed. I would go with a better spooling turbo also especially for auto-x. You can still run something kind of big since the stroker will help the spool big time. I might even stay with a green though to reach massive tq numbers. how much power does it put out at the moment?
Old Sep 8, 2009 | 02:39 PM
Tonba's Avatar
^ At the moment Im running a 20G on the stock motor with the cams, exhaust, intercooler + intake.
Its pulling 220kW (300hp) on a low reading dyno here in Sydney.
As I said before, I would LOVE to get a twinscroll something, but I just cant afford it at the moment. I'd prefer to keep the T67 and put the money towards an AP Racing Brake Kit or something..
Thanks all! Will try to keep everyone updated.
Old Sep 9, 2009 | 12:27 AM
Tonba's Avatar
Hey guys.
Im trying to decide on a twin plate clutch.
My engine builder wants to use an ORC clutch. I would like to use an exedy, main reason being money... I save about 600 using the exedy.
What do you guys think?
Any good clutches out there for a good price?
Old Sep 9, 2009 | 01:06 AM
exedy and quarter master twins are good!
