TB leak, again
Old Sep 13, 2009 | 10:27 AM
rartist's Avatar
TB leak, again
I rebuilt my 03's throttle body for a shaft leak about a year or two ago, and now I'm seeing a major leak there again. Can anyone recommend a source for a good rebuild kit?
Old Sep 13, 2009 | 10:32 AM
Import Junky's Avatar
i'm pretty sure that Mil.spec is still the main source for these seals? I've heard of more than a few people bending them slightly during the install end having leaking issues. not really sure man.
Old Sep 13, 2009 | 08:05 PM
rartist's Avatar
All I know is that it didn't show up on my May boost test, and it showed up major today. I put 65psi into my air bottle and could only build 1-2 psi boost in the motor before it all went away. As best as I can tell, that's where the sound is coming from.
Old Sep 13, 2009 | 08:55 PM
nightwalker's Avatar
It's in the install. You have to lube the rubber part with the right high temp grease, or it will dry out and catch, causing a leak.
Old Sep 13, 2009 | 09:14 PM
inslowoutfast's Avatar
Did you rebuild it with OEM seals? I just finished replacing my seal with the milspec seals. Its either them or works.
Old Sep 14, 2009 | 04:19 AM
rartist's Avatar
I don't remember who's seals I used (not mitsu), and used this MO for the replacement, which says to use dialectic grease.
I imagine there's a better grease?
