p0441 and p0011 after clutch install
Old Sep 15, 2009 | 06:30 PM
manni_t5488's Avatar
hey guys I just installed an exedy twin disk and about 25 miles after driving on it i get the cels. They are p0441 (evap system contol system incorrect purge flow) and p0011 (variable vavle timing system). Im lost cause im not really sure how the clutch might of set these codes off. Any help and suggestion would be greatly appriciated
thanks
Old Sep 15, 2009 | 06:33 PM
Oh i forgot but my car is a evo IX and i really didnt notice nething different while i drove the car
Old Sep 15, 2009 | 06:35 PM
JohnBradley's Avatar
Double check your intake cam sensor plug, make sure the EGR is hooked up, clear the codes, see what happens.
Old Sep 15, 2009 | 06:45 PM
thanks i will try that
Old Sep 15, 2009 | 07:22 PM
Fast_Freddie's Avatar
Veteran: Navy
Also feel on the back of the intake manifold where the egr lines go to one of the egr solenoids... may have broken one of the ports off the solenoid...
Old Sep 15, 2009 | 07:38 PM
Evoryder's Avatar
egr hose poppped off, down below throttle body...feel for it.. Key was in on position while a sensor was not plugged in, reset the ecu(like Aaron said)
hopefully that works.
Old Sep 15, 2009 | 09:43 PM
i checked all egr and the cam sensor and didnt really see nething. the hoses seemed to be on but it was dark out and i am gonna double check tomorow when there is light. I cleared the codes tho and drove around for about 15 miles. No codes yet but my car feels like its not making the power it was. It feels like it has more lag now so i am going to do a boost leak test aswell.
Old Sep 16, 2009 | 11:57 AM
how do I check my cam angle sensor to see if it is working properly? Im not really sure what to look for.
Old Sep 16, 2009 | 12:03 PM
I have also searched and seen this code has pooped up on some cars after intalling cams. I have 280/272 kelford cams but they have been in for about 3000 miles and not one code until after the clutch install. And I remeber that my battery was also shorted out after we put the clutch in (a socket fell on the pos and neg of the starter and was touching both at the same time). I had to get a new battery because of this. Im not sure if that could have nething to do with that iether. Thanks for the help so far
Old Sep 16, 2009 | 01:00 PM
chin0's Avatar
well after i installed my exedy twin disc clucth i put a little crack/cip on the EGR solenoid and now im told to go buy a EGR circuit to replace it.....im in the same boat brother, but i rested the my code is p0403.....
Old Sep 16, 2009 | 10:26 PM
Evokid03's Avatar
we check out the cam angle sensors and they r fine
We still gettting the p0011 code
Old Sep 16, 2009 | 10:29 PM
the egr code is gone now and the car feels like its runing fine and like ^^^ said the cam angle sensors are working fine too.. and other sugestions?
Old Sep 16, 2009 | 10:42 PM
Evokid03's Avatar
After doing some reading we r gonna check the the sprocket that is held in by a 12mm bolt on the driver side of the cams.
i wana make sure they r not 180 degrees off
Old Sep 20, 2009 | 09:53 PM
YzBrad99's Avatar
Camshaft Position - Timing Over-Advanced or System Performance
Old Sep 21, 2009 | 01:33 AM
06mr775's Avatar
I believe there is 3 vacum lines that go to your EGR they pop off all the time during a clutch install due to the motor rocking back and forth when all the mounts are unbolted and when the hoses dry out they just pop off on their own... make sure they are not torn or popped off and then zip tie them. Also trace them to the source and make sure they are attached there as well. Also on the cam sensor make sure the wires arent pinched.
vtsnake
May 24, 2012 07:54 PM
evosweens1
Nov 27, 2011 07:44 AM
bchappy
Jul 4, 2011 11:33 AM
nitz
Jan 2, 2009 02:15 PM
lancerMRguy
Jul 6, 2008 09:38 PM
