Idle Problem?help
Old Sep 19, 2009 | 12:26 AM
aguita's Avatar
Idle Problem?help
I need to change my rpm to bump it up.
With AC on and pulling up to a stop light, I take it out of gear and rpm drops too low, sometimes it shut down.....I cleaned the TB and everything and same thing..I Messed with the screw on the TB and it seemed to help a lil but now when coming to a stp the RPM stays on the 1400-1600 range for a bit then comes down..I know that this screw is for setting the TB closed position, I want to set it to the stock position again,Should I turn in Counter or Clock? how far? are ur cars idle controlled by the ecu?
where should the idle should be? the adjustment must be done with the AC?
What could be the cause of this Stalling?
thanks
Old Sep 19, 2009 | 02:46 AM
SpoolinUp's Avatar
Silver Sponsor
What BOV? Are you venting to atmosphere? Is your Idle Speed Controller plugged in? Did you properly adjust the Throttle Position Sensor if you removed it?
As far as the idle screw, every car is set differently. For now a setting of about 800-900 with car warm is fine. Clockwise lowers idle, counter raises.
__________________
-Matt- http://www.SpoolinUp.com
"Performance without the Price Tag"
Old Sep 19, 2009 | 08:23 AM
aguita's Avatar
Yep everything is plugged in, I got a hks recirculating,this happens out of boost,any other suggestions? What about the udle controlled by the ecu?
Old Sep 19, 2009 | 08:43 AM
italianevo88's Avatar
my car goes into low idle due to cams and BOV dumping to the atmosphere but it never shuts off, I think it could just be the idle screw
Old Sep 19, 2009 | 11:19 PM
vegas702evo's Avatar
mine does the exact same thing ever since it was tuned last. What could it be?
Old Sep 20, 2009 | 12:58 AM
buchnerj's Avatar
To the OP are you running cams?
Old Sep 20, 2009 | 10:31 PM
aguita's Avatar
nope n cams
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
Raceghost
25
Jan 27, 2017 03:20 PM
3gEclipseTurbo
Dec 11, 2010 05:56 PM
shadow1
Apr 4, 2009 01:43 PM
2Evo4U
14
Jul 10, 2003 04:21 PM
