only running on 2 cylinders
Old Sep 26, 2009 | 11:04 AM
cbuster77's Avatar
ok so i had my motor built and used a different ecu with a flash now i got the motor back together and doesn't throw any codes but its only running on 2 cylinders.i tried checking the spark using a visual coil spark check tool my dad had,on cyl 2 and 3 when running the light was blinking rapidly to show spark was there,on and off on and off very quickly like it should,on cyl 1 and 4 and light was on constantly,what could cause that?im guessing that means it does have spark but isn't firing but what could cause this?
Old Sep 28, 2009 | 12:23 PM
cbuster77's Avatar
is there a specific way the cam sensor should go in?it seems to only go in one way
Old Sep 28, 2009 | 12:31 PM
JakeTheVIII's Avatar
Check the voltage to the injectors. Antilag200's recent build brought some little quirky problems to my attention recently. Sounds like it might be one of these things.
https://www.evolutionm.net/forums/7524838-post77.html
https://www.evolutionm.net/forums/7538254-post100.html
Hope that helps. Keep looking.
Old Sep 28, 2009 | 12:38 PM
cbuster77's Avatar
ill try that,its weird no cel,every so afton comes up with the random misfire code,thats it
Old Sep 28, 2009 | 12:51 PM
meckert's Avatar
You check the firing order? You said it runs on 2 cylinders--I would think it wouldnt start at all. I have never been able to make one run on 2 cylinders. But check the simple things first.
Old Sep 28, 2009 | 01:10 PM
cbuster77's Avatar
i really dont know to much about the mechanics,i pretty much relay info to my uncle n hope sumthin works lol how do i check the firing order?
Old Sep 28, 2009 | 01:21 PM
meckert's Avatar
1-3-4-2, #1 is the front cylinder, closest to the belts/ pulley. Pull the dist cap off turn the distr --hit the starter looking at the rotor for the direction it turns.
So, the wire hooked to #1 cylinder, the next one in the direction the rotor is turning should be connected to #3 cylinder and so forth. then the next should be hooked to #4 and finally #2...sounds like you have them out of order to me.
Old Sep 28, 2009 | 01:28 PM
cbuster77's Avatar
evos dont have a distributor
Old Sep 28, 2009 | 01:30 PM
meckert's Avatar
you know your rt, thats just the old school in me trying to help out-- good luck!
Old Sep 28, 2009 | 01:37 PM
cbuster77's Avatar
ha,thanks anyway
Old Sep 28, 2009 | 03:01 PM
cbuster77's Avatar
i checked the fuel injector clips are they are getting the 12 Volts on all four
Old Sep 29, 2009 | 12:15 PM
cbuster77's Avatar
ne ideas?
Old Oct 1, 2009 | 12:31 PM
cbuster77's Avatar
ttt
Old Nov 7, 2009 | 01:22 PM
cbuster77's Avatar
i fixed the problem,it was the ecu,but ever since i got the herad rebuilt the car smokes now badly,what could cause this?is it possable i hooked up lines wrong on intake mani?
Old Nov 7, 2009 | 01:51 PM
EvoRob22's Avatar
What color is the smoke? Does it seem to be coolant smoke or oil burning smoke? Lots of things can cause smoke.
