coolant temp not stable, please help
Old Oct 17, 2003 | 08:21 PM
cityhugo's Avatar
hi, i just install samco hosts(rad and intercooler), hks ground wire, arc thermostat and hks coolant today i have some problem with my car, it starts fine, but after like 10 block of driving, my coolant temp SKY ROCKET, i open my hood, feel the upper radiator hosts, and is COLD, so i open the radiator cap, BIG MISTAKE!! all the coolant shoot out to the engine, so i close the cap back, wait a while and start the engine again, now i feel the upper hose again, now is hot, so i though everything was fine and went to work, and tonight when i am driving home, same **** happen again, so i open my hood and notice all my coolant r gone??!! I don't know what wrong with my baby =(, please help...
btw, my coolant temp is not stable, if i drive on the highway, the coolant temp drop to 1/5 from the baseline, and my engine rev to 1500 at idol, i am gussing is because my temp is so low, the ecu rev the engine a bit higher, but i don't know what to do, do u guys think is the arc thermostat? or something else, any input?? many thanks in advance, as for now, i am dumb founded haha...
Old Oct 18, 2003 | 12:29 AM
BadazzCR's Avatar
check you coolant temp sensor wire mine frayed and caused my cars temp to read really high when in fact the car wasn't hot at all. You can find the sensor located on the front of the thermostat housing, it will the single wire that faces the front bumper. Follow that wire back to the harness you migh have cut or scrapped that wire on accident causing it to ground out and sending you a false reading.
Old Oct 18, 2003 | 12:33 AM
timzcat's Avatar
Most likely there is air in the cooling system. The air gets trapped at the thermostat and it doesn't open because it's not hot like the coolant. You just need to get the air out.
Raceghost
Aug 10, 2018 10:39 PM
nor11384
Feb 12, 2016 09:33 AM
Lucas03ES
Lancer Troubleshooting
Aug 2, 2010 12:16 PM
EvilDylan
Oct 13, 2005 09:50 AM
