Buschur Dual pump, how much power?
Old Sep 26, 2009 | 05:07 PM
dsm25psi's Avatar
How much power can i run on buschur dual fuel pumps before running out of fuel? I keep hearing that they will not make it into 800s, that i would need to get bigger pump.
Old Sep 26, 2009 | 05:19 PM
marcmags's Avatar
1 255 wal. pump can handle 500hp. the dual should be good 900-950hp
Old Sep 26, 2009 | 05:28 PM
Dragking2189's Avatar
I dont know about BR double pumper , but my buddy made 856whp with a Full blown with -8 feed and -6 return lines, 1600cc injectors, automotive -10 FPR . AMS fuel Rail, remember E-85 need more volume than pressure
Old Sep 26, 2009 | 05:35 PM
dsm25psi's Avatar
well i dont know if i could up grade the fuel lines to -8 and -6 because because all the connections are for stock fuel lines. I wanted to know if anybody ran this kit with e85 into 800s with any problems?
Old Sep 26, 2009 | 05:43 PM
urv8aux's Avatar
talk to mike @awd i believe he made 900 + on the 6765 on e85 and the br double pumper
Old Sep 26, 2009 | 05:48 PM
GotWheelHop's Avatar
Mellon is into the 700 range with his double pumper and e-85(similar power to your setup)..... You might want to PM him and see whether he is running out of fuel.
Old Sep 26, 2009 | 05:52 PM
Pure Playaer's Avatar
No he didn't.
OP: Are you running E-85 or race fuel?
Old Sep 26, 2009 | 05:56 PM
urv8aux's Avatar
Originally Posted by Pure Playaer
No he didn't.
https://www.evolutionm.net/forums/aw...-t3-turbo.html
Old Sep 26, 2009 | 05:58 PM
dsm25psi's Avatar
I run e85 and so far so good, but im not sure how much fuel i had left at 771 i might have to ask my tuner. I know mike uses external pump
urv8aux's Avatar
my mistake
Old Sep 26, 2009 | 07:01 PM
project_skyline's Avatar
Also curious. Maybe upgrade to his twin modified HO pumps, if he still makes them.
Old Sep 27, 2009 | 05:41 AM
Mellon Racing's Avatar
right now I have the twin buschur walbro HO setup, stock fpr, buschur fuel rail and I'm experimenting with 1650cc injectors... DLL said 675awhp a DynoJet said 705awhp and my IDC is 90% on e85. 800+ might be a problem.
Old Sep 27, 2009 | 10:44 AM
dsm25psi's Avatar
do you have the Buschur Racing Dual Fuel Feed Line Kit upgraded? i wonder how much more that helps
Old Sep 27, 2009 | 10:52 AM
stock fuel lines
Old Sep 27, 2009 | 11:09 AM
oofastlineoo69's Avatar
no. mikes running a awd fuel kit.
fuel surge tank.....fpr...weldon 2035...stanless steel lines....
