View Poll Results: What Weight Oil Are You Using?
0W-30
23
5.67%
5W-30
81
19.95%
10W-30
174
42.86%
0W-40
2.22%
5W-40
15
3.69%
10W-40
24
5.91%
0W-50
0.99%
5W-50
10
2.46%
10W-50
0.99%
15W-50
23
5.67%
20W-50
30
7.39%
10W-60
0.99%
Other please post what it is
1.23%
Voters: 406. You may not vote on this poll
Old Mar 11, 2010 | 08:54 PM
  #181
SWOLN's Avatar
Originally Posted by dambikeracer
Is more then one company going to be bringing it out at that time?
The fourth quarter of 2010 is the end-date the entire industry is waiting for. At this time, oil marketers, who have filed for and obtained their API GF-5 License, can display the API starburst signifying their oil as API licensed and certified. GF-5 specified motor oils will hit the marketplace after years in development. Anticipating the introduction of the Model Year 2011 cars, the actual API first license date is expected for sometime in 4Q 2010.
Old Mar 14, 2010 | 02:56 PM
  #182
dambikeracer's Avatar
I see! Thanks for the info!
Old Mar 15, 2010 | 09:02 AM
  #183
MrHouse's Avatar
10w30 mobile 1.
Old Mar 15, 2010 | 06:02 PM
  #184
lan_evo_mr9's Avatar
Castrol 5w-40 (Audi spec). If it's good enough for those sludging, tight tolerance engines, then it's good enough for me. Plus it's free
Old Mar 15, 2010 | 07:31 PM
  #185
Colt4g63's Avatar
Amsoil 20W50 here. But its in a built AMS 2.0 is the reason for the heavy oil WT.
Old Mar 16, 2010 | 01:40 PM
  #186
apagan01's Avatar
Is there a pattern here on evom,,, i have noticed that the highest horse power evos are running AMSOIL.
hummm,, something must be working.
Old Mar 16, 2010 | 01:44 PM
  #187
SWOLN's Avatar
Oh Brother...
Old Mar 16, 2010 | 03:27 PM
  #188
apagan01's Avatar
Oh Brother...
i gota brag !
Old Mar 20, 2010 | 03:44 PM
  #189
Wheatley's Avatar
600+ 20-50 brad Penn
Old Apr 4, 2010 | 09:00 PM
  #190
Just to clarify, I don't run Amsoil in my engine, I run Alisyn from Aerospace Lubricants.
Have you ever ran Amsoil? Amsoil seems out perform the Alisyn on the scar test, I found that when I was researching your oil.
Old Apr 5, 2010 | 09:03 AM
  #191
SWOLN's Avatar
Without trying to get into a pissing contest. Yep, I've run it, and the Amsoil does outperform Alisyn in the scar test. What you should have noticed when researching the Alisyn are the Falex load preasures. They are typicallty 1000 lbs higher than other synthetics. What that means to you is that the sliding properties, pre metal to metal contact, are higher and keeps a thin film of oil inbetween the two metals long before you need to worry about the scars in the metal. It also allows you to run a lighter weight oil without worrying about contact also. I'd actually like to see the Falex tests from the Dominator oils if possible. I've looked, but to no avail. Maybe apagan01 has them...
Old Apr 8, 2010 | 02:03 PM
  #192
sandman121383's Avatar
5w30 mobil 1
Old Apr 8, 2010 | 02:05 PM
  #193
apagan01's Avatar
Originally Posted by sandman121383
5w30 mobil 1
check out this thread boom29 ran some test on that oil,, pretty good oil but did not give him what he was looking for,, but again his situation might not be yours
https://www.evolutionm.net/forums/se...ck-review.html
Old Apr 9, 2010 | 12:11 AM
  #194
boostinmarc4's Avatar
Castrol 10-30
420 whp 57 trim and gsc s2's
Old Apr 9, 2010 | 12:16 AM
  #195
u189961's Avatar
amsoil 10w30 for the last 3 oil changes.
