View Poll Results: What Weight Oil Are You Using?
0W-30
23
5.67%
5W-30
81
19.95%
10W-30
174
42.86%
0W-40
2.22%
5W-40
15
3.69%
10W-40
24
5.91%
0W-50
0.99%
5W-50
10
2.46%
10W-50
0.99%
15W-50
23
5.67%
20W-50
30
7.39%
10W-60
0.99%
Other please post what it is
1.23%
Voters: 406. You may not vote on this poll
Old Dec 23, 2009 | 06:33 AM
  #121
SmurfZilla's Avatar
I'm on Eneos 0w-50 right now.
Old Dec 23, 2009 | 09:25 AM
  #122
SWOLN's Avatar
When some of you guys decide to switch from a 50 to a 20, make sure you monitor the load cells your car hits. Some of them will change...
Old Dec 23, 2009 | 09:41 AM
  #123
apagan01's Avatar
Originally Posted by DBallz
Reading Comprehension is my friend basically anything colder then -60 the oil will freeze or should I say become hard and the oil will begin to boil or burn with temps over 446. Could you share the pour point and flash point on ATM 10W-30 and RD30? Thanks
i like you, you get it quick
ATM 10W30 flashes at 439 F, and it pours at -54 F
RD 10W30 flashes at 453 F, and it pours at -44 F
SSO 0W30 flashes at 446 F, and pours at -60 F
Old Dec 23, 2009 | 09:42 AM
  #124
apagan01's Avatar
Good info thanks for sharing.
Old Dec 23, 2009 | 11:25 AM
  #125
Gary@MellonRacing's Avatar
people on the fp reds in the 500 hp territory ?? what r u using
Old Dec 26, 2009 | 04:38 PM
  #126
dambikeracer's Avatar
I like Amsoil SSO 0w-30 or HDD 5w-30 for fall through spring. In the summer I will run AMO 10w-40
http://www.amsoil.com/storefront/sso.aspx
http://www.amsoil.com/storefront/hdd.aspx
http://www.amsoil.com/storefront/amo.aspx
Old Dec 26, 2009 | 04:54 PM
  #127
IndyEvoVIII's Avatar
Mobil 1 10W-30 currently
getting ready to switch over to AMSOIL
Old Dec 26, 2009 | 05:01 PM
  #128
sktng22's Avatar
stock turbo 320whp 10w30 all year
Old Dec 29, 2009 | 11:48 PM
  #129
Did that answer your question???
Old Jan 8, 2010 | 12:47 PM
  #130
subaruwrx420's Avatar
Originally Posted by apagan01
Hey subaruwrx420 do you mind sharing on here what are your thoughts on this oil, if you have any.
As promised here are the results of the SSO 0W30 in my S14...I know this is an Evo forum and I will post those results in the near future.
The car consumes about 1-1.5 qts per 3,000 mile interval; however, I think most of that is actually leaking via the front and rear main seals and possibly the oil pan. I have been running Amsoil Signature Series 0W30 for a full year now. I was mostly concerned about the strong fuel smell when I checked the dipstick. Results seem pretty good overall.
At the the time the oil sample was taken I did a compression test that surprisingly yielded 190 dead even on all 4 cylinders. It was done using an old AutoZone-type compression tester with a baterry charger hooked up, fuel pump relay was unpluged, throttle was at 100%, and the car was turned over about 5 times.
The car has not been autocrossed, raced, or abused really since I have owned it for nearly 2 years ops: However, I do the ocassional pull on the highway and take full advantage of every on/off ramp. Otherwise, the car spends most of it's days parked.
Their comment on not bringing the oil up to temp is actually unfounded as I drove the car on the highway for about 40 minutes prior to taking the sample. I think the fuel dilution is due to the overly rich tune of the ECU. I don't think there's a leaky injector...and all the plugs looked even when I changed them as well.
Relevant mods:
- stock 170,000 miles short block
- stock 50,000 miles head
- 248/248 S13 cams
- Leone custom tubular exhaust manifold
- 50 trim w/.63 ar at 12psi
- 550 RX7 injectors
- S13 Enthalpy ECU w/adapter harness
- all other supporting mods
Old Jan 8, 2010 | 03:16 PM
  #131
kiprosgt's Avatar
Oberon 15W60 + 850R
Old Jan 8, 2010 | 05:26 PM
  #132
Originally Posted by kiprosgt
Oberon 15W60 + 850R
That is some thick A$$ oil!!!
Old Jan 10, 2010 | 11:18 AM
  #133
kiprosgt's Avatar
thats due to extra hot climate conditions where i live.
during summer the average temperature is 116F.
Old Jan 12, 2010 | 04:48 AM
  #134
apagan01's Avatar
Very good report, and very nice for a high milleage motor.
that SSO is doing its job at maintaining the TBN super high even when you are fuel diluting it.
Relevant mods:
- 248/248 S13 cams
- 550 RX7 injectors
Old Jan 13, 2010 | 02:07 PM
  #135
E85evo8's Avatar
I'm currently running 15w-50 RD Amsoil and thinking about switching down to a 5w-50 (not sure what brand) synthetic, but not sure if there is a real benefit or worth switching due to the very cold temps we are seeing up here in NY. What do the oil gurus advise?
