High Compression Help
Old Sep 29, 2009 | 09:31 PM
MitsoKid's Avatar
Okay, I started a thread earlier because i needed help diagnosing whats wrong with my car.. i am 90% sure I broke a ringland.
So now its time for the build.
Im running an FP Red and want to make some decent power.
The guy I bought the car from claims it has Carrillo H-Beam rods and JE pistons. I have not torn into the engine to see what it really has though.
So here's my thought and what I need help with:
SuperTech 9.5:1 pistons
if it doesnt have carrillo rods then Eagles
Dual valve springs
1mm oversized vales (inconel exhaust)
GSC 272 cams
port and polished head
ACL bearings
water pump
oil pump
all new gaskets and hardware
ARP headstuds.
What I am thinking is that if I bump my compression up I can get my torque back form the Red and if I keep it Standard bore and stroke I can rev the hell out of it.
I was thinking of lowering the deck height and trying to get the CR to 9.8:1 but Im not an engine builder and i dont know if the parts above would help me do that or not?
Suggestions, Advice?
Old Sep 29, 2009 | 09:37 PM
WHTEVO's Avatar
So what makes you think you broke a ring land? It must smoke like a ***** etc if so.
Yes, lowering the deck height will raise your compression. You will want to make sure the valve reliefs in the pistons etc are large enough to compensate for what you are doing. Why not just go with some higher compression pistons rather than trying to do it by doing something that isn't reversible? Good luck.
Aaron
Old Sep 29, 2009 | 09:39 PM
MitsoKid's Avatar
Aaron
I want to run on pump gas and I dont have much money to play around with. Who makes a 9.8:1 piston? From what I have read to run 10:1 or higher you really need at least E85 or equivalant.
Old Sep 29, 2009 | 09:53 PM
dambikeracer's Avatar
Read my thread
https://www.evolutionm.net/forums/ev...ine-build.html
Old Sep 29, 2009 | 10:00 PM
MitsoKid's Avatar
Originally Posted by dambikeracer
Haha I did already. It just seems to be a bunch of arguing.
I think that I will stick with the 9.5:1 ratio. I do not live in a area that sells E-85 and I would hate for E-85 to be taken off the market, I have already heard rumors of this. I just want some more N/A power before I hit boost, I have absolutely NO torque going to the RED.. I suppose I could have had a cracked ringland for a while though? I didnt even know until I checked the compression because I was still making like 370whp.. lol
This is a budget (unexpected) build. Im not looking to spend gobs of money on my DD/Track Car.. I will save that money for the real race build later down the road.
GravityKnight
21
Mar 2, 2019 01:30 AM
theblackbeast11
May 26, 2015 12:27 PM
TURBO_S2K
23
Oct 25, 2012 01:39 PM
RealStreet
Evo 'For Sale' Engine Internals and Drivetrain
63
Oct 17, 2012 09:12 AM
AJW Performance
EvoX 'For Sale' Engine Internals and Drivetrain
Jan 12, 2012 09:50 AM
