Transfer Case Problems Please Help
Old Oct 1, 2009 | 04:23 PM
krypt952's Avatar
Sence day one I got the car it had the transfer case death whine, or atleast I think it was that, however other then the whine there were no big problems with the car, the car has 49000 miles, and according to recipts the original owner had " transmission rebuilt with different gears and 4 puck clutch, rebuilt rear diff, and new lsd transfer case." installed under 5k miles ago. So I just figured it couldn't be the death whine considering all of that stuff was recently replace, I just figured it was maby some heavy duty racing transfercase/gears in the tranny.
So the other day I realized a huge leak comming from the transmission area under the car, I had it towed to a local transmission shop, and they claimed all the fluid in the transfer case leaked out and got into the transmission overflowing the transmission fluid and that was the reason I had the leak, they also claimed that the whiny noise was due to the bearings on the transfer case, now I think there full of complete bull****.
I think the whine in comming from rack and pinion in the transfercase, meaning I need a rebuild or a new transfer case.
My main concerns is I dont have alot of money right now because I just payed off both my credit cards, and I dont wana spend money on the wrong parts,
Thank you for taking the time to read this and any help would be appreated thank you.
Aaron
Old Oct 1, 2009 | 05:54 PM
krypt952's Avatar
Also Can I buy a evo 9 transfer case and bolt it up as long as its a 5 speed? and I see all this stuff about ACD would I need ACD?
Its for a 2003 Evo
Old Oct 1, 2009 | 06:01 PM
BluEVOIX's Avatar
You can not put an ACD on your evo because you would need an ECU for acd, and a pump. Turning an non ACD evo to an ACD evo is not worth it and will cost a lot of money.
If you were to get another transfer case, just a non ACD tc with LSD in it.
As for fluid leaking into the transmission, I'm not even sure if thats possible. Anyone care to chime in?....
Old Oct 1, 2009 | 07:30 PM
ctbz860's Avatar
thank goodness there is this website to get second, third, and fourth opinions... especially when you feel like you're getting a **** load of BS from so called "experts"! LOL, but then again they could be right...
Evo__Lee
Oct 4, 2018 10:23 PM
09Ralli
Sep 19, 2015 06:24 PM
booosted
Sep 2, 2015 05:38 AM
deuce329
May 10, 2009 06:00 PM
Solo II Evo
Apr 22, 2009 03:08 PM
