SpoolinUp COP installed
Old Oct 4, 2009 | 06:35 AM
SpoolinUp's Avatar
Silver Sponsor
Originally Posted by 1badgsex
man i need to get some money up to get this COP, tryin to finish my build and pull all lose ends together is harder then i thought.... money wise !!!
Well I can't help you make the money but I sure can help you save a few bills...the kind with Ben Franklin on them.
__________________
-Matt- http://www.SpoolinUp.com
"Performance without the Price Tag"
Old Jan 12, 2010 | 04:16 PM
EGbeater's Avatar
Originally Posted by SpoolinUp
Check out the site. I offer both new and used coils. The choice is of course entiurely yours.
The stock cover will not fit with kits right now. Soon the new kits will fit under. Used likely never will.
I've had the SpoolinUp COP system (used coils) installed for a week or so now, and it's quite a noticeable improvement over the OEM ignition system. I haven't tracked my fuel economy over a full tank yet, but just by the way that I'm at over 130 miles so far, and the gas gauge needle isn't even down to 1/2 yet (I run E85 and 1,000cc injectors; it goes fast), I know I'm getting siginificantly better fuel efficiency.
I'm also 100% fine with the fact that the OEM plastic valve cover insert goes away - the SpoolinUp system looks great, and with the plastic cover gone, there's almost NO weight gain:
Total weight of the SpoolinUp COP system - 2.55 lb:
Total weight of OEM coils, spark plug wires, mounting bolts, and plastic cover - 2.38 lb. Total weight gain = .165 lb., or about 75 grams! I can definitely handle that for a perceivable power gain, better driveability, and improved fuel economy:
Old Jan 25, 2010 | 04:57 PM
Enzo1089's Avatar
After installing this COP, would you need a tune, or does it plug right in with no issues what so ever.
Old Jan 25, 2010 | 05:42 PM
EGbeater's Avatar
No tune required, no issues at all, but there's a good chance your Evo would make slightly more power and get better fuel economy with a retune.
After two full fillups, I can now report that my gas mileage has increased from 16.5-17 mpg to 18.5-19 mpg with the SpoolinUP ignifition system (on E85, not pump gas).
Old Jan 25, 2010 | 05:47 PM
Cyloc's Avatar
I will be looking into these right after i get my turbo rebuilt. Always interested in trying item that the everyday street car would use.
Old Jan 25, 2010 | 09:44 PM
dbsears's Avatar
Did you regap your plugs on your IX to be a tad wider or leave them at stock gap?
Old Jan 26, 2010 | 08:54 AM
Enzo1089's Avatar
Totally answered my next question. Thanks
I think im going to get this next pay check.
Old Jan 26, 2010 | 10:29 AM
EGbeater's Avatar
Didn't regap or change the plugs. Just pulled the plastic cover, removed the OEM coils/wires, and plugged in the COP system. I might try gapping a tiny bit wider for slightly more power when I install the next set of plugs though.
I also didn't retune the car, change my route to work & back, drive differently, fillup at a different gas station, change wheels/tires, increase tire pressure, or pull my rear wing/do any weight reduction.
There is ZERO doubt in my mind that the SpoolinUp ignition system alone significantly increased fuel economy on my Evo. YMMV of course.
Old Jan 28, 2010 | 04:05 PM
bLk-Ev0-aTe's Avatar
Deff thinking about buying this.
Old Jan 28, 2010 | 04:15 PM
blackgsx01's Avatar
I just ordered mine, it was shipped out today. I hope I will get it by saturday so I can intall it with new plugs + fp black setup.
Old Feb 5, 2010 | 06:45 PM
tristat3's Avatar
what spark plug gap size are you guys running with this kit?
Old Feb 5, 2010 | 08:06 PM
boostin350z's Avatar
swhats the average price you can get these for? used or new doesnt matter
Old Feb 6, 2010 | 05:24 AM
bbyevo8u's Avatar
do you sell new cop kits?
Old Feb 6, 2010 | 08:28 AM
EGbeater's Avatar
.023", Denso Iridium IKH24. E85, 33 psi peak boost, Cosworth M2 cams, 5,000 ft. elevation.
Should be able to go a tad bigger, that's just how I had gapped them when I installed the plugs new around 6k miles ago.
Old Feb 6, 2010 | 08:31 AM
SpoolinUp's Avatar
Silver Sponsor
Will be a Denso vendor with any luck in a week or two. Also I'll have some bangup prices on Iridiums!
__________________
