Question on Boost Leak Test
Old Oct 2, 2009 | 11:53 AM
rusty11's Avatar
So i just installed the Injen intake with the upper and lower ic piping, and i'm not sure if the new noise my evo makes is a big boost leak or if its the way the new intake is supposed to sound? Im tapering from 22 psi clear down to 14 psi. So i assume i have a pretty good leak somewhere, i already replaced all my hose clamps with t-bolt clamps and the taper isnt as bad. So my question is....can i just hook up the leak tester to the intake where the filter would normally sit or do i have to put the tester on the turbo inlet? Obviously i would rather just hook it up to the intake as that would save a lot of time and hassle.
Old Oct 2, 2009 | 12:10 PM
bluebanana23's Avatar
turbo intlet, should only take an extra 10 minutes
Old Oct 2, 2009 | 12:11 PM
gsrboi80's Avatar
I've always connected them to the turbo directly when doing a leak test
Old Oct 2, 2009 | 12:21 PM
Tnnrx7's Avatar
Follow this guide and do it right
http://www.evogarage.net/2009/05/08/...t-leak-tester/
Old Oct 2, 2009 | 12:22 PM
yahu's Avatar
+1 for hooking it to the turbo. It won't take that much extra time.
Old Oct 2, 2009 | 12:24 PM
yahu's Avatar
Originally Posted by bluebanana23
turbo outlet, should only take an extra 10 minutes
Turbo outlet? Maybe that has been my problem?
Old Oct 2, 2009 | 12:35 PM
haha good catch
Old Oct 3, 2009 | 01:32 AM
yahu's Avatar
