help request, my lazy Evo 8??
EVO8 installation list: Engine
·HKS turbo kit GT 3240 A/R 0.82 GT wastegate, manifold.
·GT3048R (similar to HKS GT3240), mild street.
·D2 adjustable suspensions.
·1000 cc power inter price injectors.
· double internal fuel pump.
·Sard fuel line.
·Sard fuel regulator.
·OS twin plate clutch., changed to spec twin plate hydraulic clutch ( i have problems with this clutch)
·Koyo radiator + samco silicon pipes.
·AMS cooling fan.
·Grreddy inter cooler 3 Inch intercooler pipes.
·Double oil cooler, original + HKS
·Tomei cam shafts and cam gears 280 degree
·Modification and enlarge oil pan.
·Motec m800 plug and play.
·3 Inch direct exsust.
·Head ported and polished, Tomei valves springs.
·Tomei 1.6 metal gasgate.
·greddy boost control.
·HKS turbo timer.
·Trust air filter with 3 inch intake pipe.
·CO2 cooling gas.
·Kansai intake manful
my Evo 8 is running on 1.2 low boost and 1.7 high boost
due to the extremly hot weather ( 35C in the mid)
and Now the biggest problem is the Turob Lag
the turbo opens at 4500 RMP and gives its full 1.7 or 1.2 at 5000 rpm its extremly laggy
i have been told its due to the laggy turbo 30.40 ( i heard it has been canceled deu to this problem)
and the large 280 cams
the car has been programmed ( tuned) yesterday, and the tuner told me about the lag
the tuner said it is near 390 AWHP ( no dyno)
and i heard from many guys that is should atleasdt produce 430 WHP on this setup
So guys any request so i can decrease the lag
any help or faulty things in the modificated parts please tell me about them
Sure there is lots of solutions, they are just probably not what you want to hear....
1. THe intake Manifold loses some spool but you make big gains up top
You can look at either changing the turbo to something smaller and still make the same power such as an FP Red Turbo
You can upgrade your engine to a 2.3 Stroker and you will pick up a lot of spool up there..
you could swap out your kansai intake manifold with a ported stock intake manifold and help gain some spool up there....
these are all options that you probably don't want to do, im sure your looking for a fix with your exact setup..
If it was me, I would save up for a 2.3 stroker engine and call it a day! That would really turn the spool up around and maybe consider buying a stock ported intake manifold and trying that as well to see. Im sure with a 2.3 stroker and a stock ported intake manifold would help spool up by at least 500-700 rpms
but i heard i can either change the turbo head to garrot 30.37
or change the cam size to 272
or stroke the engine
i have read that the 30.40 tubo is laggy that is why they stopped it
so what do u recommend?
thank you fro your help
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Your intercooler is killing you. A 3" core just won't cut it you need something like a 4" BR racing IC. You might want to get ride of that turbo and get a PTE 6262 or FP HTA3586
So the turbo you have is like a GT3082R someone on this forum once said all the lag of a 35R but not the power...
For beter spool you can go smaller GT3076R / HKS3037
or for even better spool get a FP HTA3076
A 2.3L would really help you though...
i think the only type of turbos that would fit are 3037 or 3240 on the same housing
what about the cam gears?
I am going to stick with my guns and recommend
a stroker kit ( 2.3 ) AMS or Buschur
GSC1 Cams
Stock Ported Intake Manifold
I would buy a Red which is proved to make up to 550+ whp on race gas
That is what i would do -
The turbo itself would make me think what you are going to do with the car....
street car - FP RED TURBO or a TWIN SCROLL 35R
Drag Car - TWIN SCROLL 35R or the TURBO recommended above
For reference - i used a 50 trim bb turbo and with a stroker kit made 500 whp and 475 lbs and seeing full boost by 4000 rpms
GSC1 Cams
Good point - its a HKS Turbo kit so the best bet for a turbo that bolts-on with this kit is the HKS 3037 for better spoolup; add a 2.3L to that and you will see full boost before 3800 rpm...
3037 on a 2L see full boost about 4300rpm
oh yeah and a .63AR is big enough for a 2L...
3 inch intercooler piping is a bit big for the power your making. go with 2.5 piping. larger piping = more area to pressurize to make boost. Usually only necessary when making high horse power...my 2 cents
I would also suggest if your having a problem with that clutch to switch to a Exedy Twin Disk HD....
Very grabby and a very nice clutch.
So all in all, I think we need about $5-9,000 to get your car to spool quick and make great power... LOL
That includes a 2.3 stroker by the way....
I can't tell you enough as many people will that a 2.3 on a street car is pure sex....
my car gained 60-70 ft lbs of torque on crappy cams...
FS[West]: FS (AZ) Apex Silver Evolution VIII GSR
bluepeartype-s
For Sale - Cars For Sale
12
Feb 24, 2016 07:44 AM
FS[SouthEast]: 2005 Evo MR. 400 whp. Shep Trans. South Florida
RGV250
Oct 16, 2014 10:50 AM
Kaane
Jun 1, 2005 02:58 PM
