diffrence between 8 and 9 turbo?
Old Oct 7, 2009 | 02:36 PM
john blaze's Avatar
just wanted to know whats the diffrence between two turbos besides the 9.5 hotside and 10.5 hotside? thanks
Old Oct 7, 2009 | 02:38 PM
buchnerj's Avatar
the search button is your friend
https://www.evolutionm.net/forums/ev...8-9-turbo.html
Old Oct 7, 2009 | 02:52 PM
john blaze's Avatar
thanks bro
Old Oct 7, 2009 | 06:22 PM
sparky's Avatar
As you mentioned, the earlier USDM VIII turbos(2003-2004?) had the 9.8 turbine housing whereas all the USDM IX turbos are configured with the 10.5 housing.
The center housings as well as the compressor and turbine wheels are the same on the VIII and IX 16G´s. The single puck turbine 10.5 housing found on the 2005 USDM VIII´s is the same one used in 2006 on the IX turbos.
The only significant difference is the IX turbo´s improved compressor housing design. This requires a somewhat different compressor backplate as well. So, comp housing and comp backplate/diffuser change from VII to IX turbos.
Old Oct 9, 2009 | 06:04 PM
hoof hearted's Avatar
Sorry---- wrong spot for sale!
Old Oct 10, 2009 | 01:35 PM
RSMike's Avatar
Originally Posted by hoof hearted
I am selling a complete 2005 turbo assembly (20k mi)-- from ex. manifold to 10.5 hotside O2 sensor return tube.... etc...--- still together and in one piece... Unfortunately I have not made enough posts (even though I have managed to achieve an itrader rating of 4communicating through PM's) to get it on the for sale threads...
Good stuff.
$325.
PM sent
Old Oct 10, 2009 | 04:22 PM
Does the compressor stamping on the 9 turbo say "20g" where the 8 says "16g"???
TJung
16
Oct 18, 2021 07:09 PM
me-var
Feb 13, 2012 08:48 PM
evo8fate
28
Apr 16, 2008 03:28 PM
ImportEvo9
Mar 18, 2008 03:32 PM
KS_Evo9
Dec 11, 2007 12:04 AM
