Larger T Case O Ring
Old Oct 9, 2009 | 06:46 AM
thedru13's Avatar
Quick question about this. Just want to make sure I put this on correctly. I ripped the T Case Oring. I just ordered a new one and will be here today. Is there anything I need to know before I put it on the Tcase?
Old Oct 9, 2009 | 06:51 AM
allinevo's Avatar
Clean the grove that it goes into really good then after installing o-ring make sure you lube the o-ring with either transgel or what I like to use,engine assembly lube. This will prevent the o-ring from rolling and possibly ripping.
Old Oct 9, 2009 | 06:57 AM
thedru13's Avatar
Ok thanks. Will Molly Lube work?
Old Oct 9, 2009 | 07:56 AM
kickin wing's Avatar
I actually used vasoline
I guess you could use KY if you had some handy
An04EVO
13
Oct 6, 2017 04:34 PM
Jookies
Mar 30, 2013 04:46 PM
CooleyKing
May 18, 2010 01:00 AM
milruner
10
Oct 25, 2008 09:50 PM
yasir
Jan 27, 2007 06:58 AM
