Mobil 1 FTL!
Whether Castrol or Mobil 1, they're both good oils and above the average spec. Alot has to due with oil consumption. A person may think they're consuming more oil of one type more so than the other. Maybe you are, but also remember driving habits also have to do with the usage factor just as weather does.
I have used both. I tend to lean toward castrol syntec. i think mobile1 has changed giving castrol the edge in the contest. As far as the factory fill, what does that matter its typically who they are aligned with such as racing or who gives the better deal. The weight and viscosity are the key as well always full synthetic.
man im glad someone posted this. ive got 94k on my 8. ive used mobile 1 10w 30 every 3500 miles or so. the car has never used any oil by the dipstick, but here recently ive been told by more than one person that im throwing some blueish white smoke under acceleration. i checked compression and all is good. ive been wanting to try a different oil but was apprehensive about switching. i think im going to give castrol a try next change to see if it makes any difference.
This thread has tons of statments that are not even proven. Like the one above. You really think royal purple is just a gimmick because it is purple?? Alot of the things being said are just from people who praise it because they use it. Why dont you post up some real test that prove all of your "theorys". I wil look for some actual test that were in a non-biased performance mag i used to have that showed mobil 1 and royal purple to be the best protecting under all driving conditions. Let me try and find it and i will post it up.
Here is just a tiny bit from a full on pro oil test. Including HP test, wear protection, viscosity. The oils were all put to the same test.
Overall results:
CONCLUSION
There are many names, numbers, values and suggestions throughout this article, and to an extent many of the results show how even the oils are. The one point proven is just how much better synthetic oil is over a "mineral" or petroleum based product.
In the case of a pure performance or race engine where power is priority and oil changes can be frequent, the 0-30/40 oils such as the Mobil 0-40, Castrol R, or Royal Purple would be best suited. However, for regular street-driven engines, it would be better to look at an oil with a good service interval.
An overall analysis of the 11 oils suggests in any case, see your owners manual for the recommended grade of oil. Torco and AMOSIL supplied the "recommended" oil for our testing, but added if it were an outright horsepower shootout, they too would have supplied a zero weight oil.
Although we've provided criteria to pick and choose an oil, the stand-out to us appears to be the AMSOIL, rating well in the viscosity and producing good horsepower.
In the 0 up to 40 weight category, it seems Mobil's new 0W-40 produces terrific power, insignificant viscosity loss and a middle-to-fair wear particles rating.
With the variety of grades, use this test as a guide but always follow the manufacturer's recommendation. But if we were to stick our neck out in anticipation of the law suits, from the information we gathered specific to the supplied oils in this test, we'd rate the oils in the following order:
1. AMSOIL
2. BP Visco 5000
3&4. Both Mobil 1 (difference between price)
5. Hi-Tec HTO
6. Shell Helix Ultra
7. Royal Purple
8. Castrol R
9. Castrol SLX
10. Torco
Here is the link to the full test info:
http://www.performanceoilnews.com/oi...nst_oils.shtml
Here is another test done by pro-street.
Royal purple put out the most power. The avarage baseline of the test car a 350z was 224 hp/220 TQ . with the royal purple it put down a staggering 242 hp 227TQ/!!! Talk about best bang for the buck.
Overall results:
CONCLUSION
1. AMSOIL
2. BP Visco 5000
5. Hi-Tec HTO
7. Royal Purple
8. Castrol R
9. Castrol SLX
10. Torco
everyone is entilted to their opinon, and what works for one may not for another.
I have owned my 05 Evo since day 1, and have put in nothing but Mobil 1 10w-30 in it. It has burned about a quart or so every 3,000 miles - I usually change the oil every ~4k.
I had gotten used to the oil consumption, as nothing ever showed up in the catch can, and it has always had very strong compression. I figured it was the pain of living with a turbo car that was putting down ~390ish at the wheels.
My last oil change, at ~37k, I went to go buy a jug of Mobil 1, but WalMart did not have any on the shelves. I figured I'd give Castrol Syntec a shot. Put in the ~4.5 quarts of 10w-30, and now at ~41k the oil has not moved a bit on the dipstick. Still topped up and full.
Never buying Mobil 1 again!
The one thing that I would suggest to those who are having oil loss issues, (that is an issue that is within the 1 qt for every 3000, and your engine seems healthy in all other regards, compression check, leak down, etc...) change out to a dino oil to reseat the rings. Basically, scraping the cylinder walls so that it's not smooth rings against smooth cylinder walls any more. Use it for 3000 miles and then go back to what ever oil you think is the best oil for you. ...or you could just keep adding the oil and go about your marry way, it's up to you.
