Oil coming out my bov? need help?
Old Oct 12, 2009 | 09:48 AM
twst_evo_04's Avatar
So recently I had installed injen full pipe kit and intake. I've always had a blitz bov. When changing out the piping I noticed when taking apart my maf there was some oil like subtance in their. Didn't think much of it and cleaned it up so when I do decide to put it back on it I won't have to mess with it. Now that my vent piece is facing the front towards the head light, i'm noticing the same oil like subtance that seams to becoming out of my bov. Looking more into it I see oil leaking out a bit were the hose for bov meets the uicp. What could be causing that? should I be concerned or is this normal? my car has always ran fine with the new and old piping. only difference is that p0300 comes up more often. any ideas would help. I have 86k on it and tuned with stage 1 cobb for now.
Old Oct 12, 2009 | 09:50 AM
buchnerj's Avatar
an oil catch can should help with any oil that is dripping through the pipes. How much oil are we talking about? Clean the MAF with the special spray cleaner (available at any auto parts store, CRC makes it) and see if it happens again after youve installed a catch. Should do the trick. What is your mods list? Bigger turbo?
Old Oct 12, 2009 | 10:13 AM
GaBe511's Avatar
With that many miles, could even be oil from the turbo.
Old Oct 12, 2009 | 11:28 AM
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
I would also suggest getting the compression test and leak down. you might be getting some blowby too.
Old Oct 12, 2009 | 01:20 PM
stock turbo. just new upic and licp and intake from injen. just got a oil change today so I had cleaned everything up, and already it's spitting oil out. i'll say more than a few drips.
Old Oct 14, 2009 | 07:17 AM
Will excessive blowby cause a problem if I I don't get it checked soon?
Old Oct 15, 2009 | 01:49 PM
evo8inla84's Avatar
Get a catch can dude..
Old Oct 15, 2009 | 08:05 PM
DBallz's Avatar
Yes it is possible
Old Oct 15, 2009 | 08:23 PM
my3awds's Avatar
I say everyone with a turbo engine should own a compression gauge since it's cheap. Check compression first to make sure your still in good running order then a catch can if everything checks out.
MaDD-Myke
May 1, 2012 06:44 AM
ottoman
15
Dec 14, 2011 12:32 PM
spider72
Nov 9, 2011 12:21 AM
Karass
62
Aug 27, 2010 05:22 PM
sawgunner06
Jul 17, 2008 10:15 AM
