Any new FP-BLK or BBK-XL info????
Old Oct 14, 2009 | 07:51 PM
fromWRXtoEVO's Avatar
I hate that dynosheet. You got no power at top or in the low range. All the sudden you hit full boost and tons of torque and HP but what about the before and after. That redline shows the power is falling on its face... no thanks!!
Carlos
Old Oct 14, 2009 | 07:54 PM
vmrevo9's Avatar
Veteran: Air Force
holy crap 8.5k rpm on a stroker motor! and peak torque at ~5575rpm i would have expected a better curve as well. i'm sure it will improve
Old Oct 14, 2009 | 07:56 PM
Cali2MDevo8's Avatar
Registered User
Carlos
And thats even with assistance from the 2.3. This turbo doesn't look promising for the 2.0.
FYI-i don't think it's called the BBK-XL
I should have asked Chad that the other day. I mentioned in the initial post (XL) and it seems people are running with it
Old Oct 14, 2009 | 07:57 PM
NYCFJV7's Avatar
Vid of the supposedly FP Black equipped evo on the dyno
http://www.youtube.com/watch?v=2yXT7...33E1E4&index=0
Old Oct 14, 2009 | 08:00 PM
ninekrevs's Avatar
Originally Posted by dambikeracer
What PSI was this at? how much more does it have in it?
boost level is unknown. never mentioned in any of the threads i looked at. I would guess around 30psi since it is on unleaded race gas.
Old Oct 14, 2009 | 08:06 PM
scumrat's Avatar
I hate when they put out a new product and then release results of it that were produced on a fully modded car. I would like to see what is does with just supporting mods.
Old Oct 14, 2009 | 08:22 PM
mrdevo's Avatar
I think that black dyno graph is more than 30psi from what I remember. With lower boost and a 2.0l, the graph will have a more gradual climb. 525whp at 8500rpms on a stroker is nothing to sneeze at.
Old Oct 15, 2009 | 07:19 AM
PPI's Avatar
PPI
/\ agreed...
I'm not sure why people are complaining about that dyno curve. Its a stroker motor guys! The dyno was ran out to 8500 rpm or so...most will not turn that much rpm on a 2.3.
Old Oct 15, 2009 | 09:15 AM
JDMevoBOOST's Avatar
Not only that the Cobb dyno is set up to read like a DJ, so take it for what its worth.
Old Oct 15, 2009 | 10:32 AM
OKIX's Avatar
Sir, I believe that may be incorrect.
Old Oct 15, 2009 | 01:46 PM
atkins's Avatar
Originally Posted by PPI
/\ agreed...
Yeah but take into account that it is on a stroker, and then put it on a 2 liter and u are moving the the curve to the right from slower spool which will give even less usable power except for the last 2000 rpms. To me that's not impressive. As I saId before I'm sure the drag racing fans will think otherwise but that's not my preferance. As a daily driver I think there is better options for that power level especially since the car is maxed out from the mod standpoint, unless I was misinformed.
Jeff
Old Oct 15, 2009 | 01:53 PM
2highpsi's Avatar
Jeff
I'm not "in the know", but that car i believe is Robert's and is FAR from maxed out. Heck, look at the pic, you can clearly see it still is running a factory upper IC pipe
I could be wrong though......
Old Oct 15, 2009 | 02:08 PM
RockmanX's Avatar
so for DD use then looks like i might keep my red. I dont want a drag only car how boring is that
let me revise to some its boring. ill wait for more information on the turbo before i commit to buy it
Old Oct 15, 2009 | 02:28 PM
KevinD's Avatar
if i remember correct, robert said it was 38psi in one of the threads here.
Old Oct 15, 2009 | 02:32 PM
Put a stock evo IX on that dyno and if it reads 220-230 with no adjustment I will eat my words. Until then stock turbo cars making 400whp on pump gas non-e85 on that dyno tells me it reads like a DJ.
Actually you want me to case in point this?
Show me a 73HTA Green make 450 on 93 pump on any other proper reading mustang dyno. Straight off the FP website.
http://store.forcedperformance.net/m..._Code=Turbo-FP
