Any new FP-BLK or BBK-XL info????
Old Oct 15, 2009 | 02:48 PM
  #31
KevinD's Avatar
keep in mind the car with the 450whp dyno is a 2.3L fully built with all the bells and whistles (including a MOTEC).
Old Oct 15, 2009 | 02:58 PM
  #32
atkins's Avatar
Originally Posted by 2highpsi
I'm not "in the know", but that car i believe is Robert's and is FAR from maxed out. Heck, look at the pic, you can clearly see it still is running a factory upper IC pipe
I could be wrong though......
Sir you could be absolutely right. The only info I have is based on what I have read on this forum and others. we all know how reliable that info is allthough i dont know to many people that put a 2.3 stroker in arelatively stock car.
Jeff
on another note if that is 38 psi it's even less impressive. Why do people test to promote products with such non real world info???
Old Oct 15, 2009 | 04:36 PM
  #33
PPI's Avatar
PPI
keep in mind here...much information is not known....unless I have missed it. Like seeing the boost plot for one. If the boost does hit 38psi I am willing to bet there is a big taper which explains why the torque drops the way it does. I know for a fact from our conversations Roberts car is far from maxed out.
Old Oct 15, 2009 | 05:10 PM
  #34
David Buschur's Avatar
We build strokers on a weekly basis, they are recommended to be run to 8500 rpm. They will make power all the way to that point. Check for a dyno sheet of Project White or Shepherd's or Nick Andy's for proof of that.
I also agree, Cobb's dyno definetely doesn't read any numbers close to what our dyno does, I'd agree with being close to a Dynojet.
I wish I could spill the beans on the black It's looking pretty good though, I can tell you that. Information will be released when FP is ready to fill orders, just waiting for the "go" to release our information.
Old Oct 15, 2009 | 05:12 PM
  #35
A418t81's Avatar
I wonder what they are doing to prevent massive surge. It's pretty dang terrible on the red if you drive it "right." Not knocking it, it's a hell of a turbo, and I know the 80mm compressor housing helps a bit, but bumping up to 70 lb/min seems like there would be absolutely no way around it. At that point, why not just go with an actual 35R framed HTA.
Old Oct 15, 2009 | 05:15 PM
  #36
The turbo has the new ported cover on it, eliminates surging.
Old Oct 15, 2009 | 05:23 PM
  #37
justa4banger's Avatar
Wow..this fp black turbo is gona be sickkk...watch all the fp reds go forsale..lol
Old Oct 15, 2009 | 05:27 PM
  #38
yahu's Avatar
^you looking to buy a slightly used red?
Old Oct 15, 2009 | 05:36 PM
  #39
Lol....I'm good, ill stick to my 35r
Old Oct 15, 2009 | 05:39 PM
  #40
yahu's Avatar
^you could hang it from the rearview mirror?
Back on topic - I don't know why people get bent on pre-release info (after reading the whole thread). I'm sure it will be a rockin' turbo, based on historical data. Should you get in the lineup based on the hype? I suppose that depends on where you happen to be in your build - it certainly might be worth waiting at this point before deciding on a new turbo.
Old Oct 15, 2009 | 05:48 PM
  #41
It's worth the "hype", believe me
Old Oct 15, 2009 | 05:56 PM
  #42
mpevo8's Avatar
145mph on the red..150mph on the black possible ?!?!?!
Old Oct 15, 2009 | 06:37 PM
  #43
RockmanX's Avatar
is it going to be a good DD and street turbo with decent spool is what i need to know to spend 1800 and sell my red lol.
Old Oct 15, 2009 | 08:03 PM
  #44
Thomasevo's Avatar
Im all for it!!! I mean the bang for the buck is incredible in FP's green, red and soon to be black
Old Oct 15, 2009 | 08:12 PM
  #45
wizzo 8's Avatar
Subscribed
