Verify cams..
Old Oct 12, 2009 | 01:05 PM
jyndrus90's Avatar
Verify cams..
So i'm going to pick up some used BC 272's and I wanted to know is there a way to verify that they are not stock cams, but rather the brian crowers?
Old Oct 12, 2009 | 01:10 PM
3gEclipseTurbo's Avatar
most people say bc are ****ty, idk
Old Oct 12, 2009 | 01:20 PM
jyndrus90's Avatar
my buddys 03 had a intake exhaust headstuds and 22psi tune and he was able to beat a c6 vette so i think theyre fine
Old Oct 12, 2009 | 02:37 PM
allinevo's Avatar
If they are B/C cams they will NOT be hollow like the stock cams. Also,from my limited experience installing them I believe you need the bolt that holds the cam sensor reluctor on the end of exhaust cam because they use a bolt with smaller thread (I think it's 8mm and stock is 10mm)and the stock retaining bolt will NOT work.
Old Oct 12, 2009 | 02:55 PM
JakeTheVIII's Avatar
That doesn't mean anything. A tuned stock evo can beat a c6. The BC cams do suck. They make much less power than other cams. And they're manufactured crappy, with inconsistencies with their measurements.
Weird. I installed some BC 280's on my evo 8, and they used the same stock bolt. But I had some mystery cams out of my buddy's evo 8, and they had a smaller CAS bolt like you're saying. They must be the BC's.
GSX_TO_EVO
Sep 6, 2016 07:00 AM
Omahasti
Dec 27, 2015 02:00 PM
BEISSEN
AEM EMS
45
Oct 14, 2015 08:53 PM
GrandmasterCow
Apr 1, 2013 05:33 AM
nytalonTSi
Sep 23, 2011 02:13 PM
