Ets intake w/o Tune
Old Nov 21, 2009 | 07:16 PM
  #31
mifesto's Avatar
Originally Posted by SyZyGy1394
I take it english isn't one of your strong points? I can tell because in my last post I dumbed it down pretty much as far as it can get.
No need to describe to me the process of changing the rom on your ecu. I tune my car myself so I already know my way around ecuflash.
no i just dont argue on the internet about fine points on how to refer to a "tune" or a "flash" especially with a noob whos jumped on evom maybe in the last year or two
Old Nov 21, 2009 | 11:46 PM
  #32
SyZyGy1394's Avatar
You don't argue about fine points? Then why did you try to "correct" me on what you thought I was saying?
Noob? First of all its spelled newb. Second, I wouldn't compare intelligence based on post count/join date, because that is definitely not working in your favor.
Old Nov 22, 2009 | 04:03 AM
  #33
project_skyline's Avatar
You should just quit now because your just digging a deeper hole...
I put ETS intake on without adjusting the tune for a while, its not a big deal and the only real change it needs is a little more idle fuel.
Old Nov 22, 2009 | 09:45 AM
  #34
SyZyGy1394's Avatar
I don't see how I am digging myself a hole when I'm not the one thats arguing about something that they don't know much about at all...
Care to elaborate on your "theory"?
Old Nov 22, 2009 | 09:59 AM
  #35
JohnBradley's Avatar
The new version of the ETS intake was developed on a fairly stock car (stock cams, injectors, tune) with very few performance parts in order to try to alleviate the lean idle that they had been notorious for. You very well could be a-okay bolting it on. I have only had to adjust the idle after adding cams to cars equipped with the new version, but I'd have to do that anyway to smooth it a little.
Old Nov 22, 2009 | 11:02 AM
  #36
gsrboi80's Avatar
Originally Posted by gcbandit20
you'll be fine. you won't really gain much. in some cases you lose power by adding an intake pipe with no tune but you will be fine.
This 100%
Old Nov 22, 2009 | 11:05 AM
  #37
Your arguing about something that isn't clearly different.
1. A flash and tune can be the samething! Doesn't always mean base flash, could be custom flash AKA e-flash.
2. Your annoying and your arguing is going
So quit trying to act like king dingaling.
Old Nov 22, 2009 | 11:37 AM
  #38
SyZyGy1394's Avatar
It all depends on how you want to view it, if you want to put it that way. You personally, can call it whatever you want I guess. I'd rather not use the same word for 2 different things. Mainly because it confuses all the retards on here.
The fact that you joined in is making it go even more off topic, so don't complain about that at all.
Keedo
Cobb AccessPORT
Oct 20, 2014 07:47 AM
joey0480
Nov 30, 2013 02:17 PM
The_X_Effect
Cobb AccessPORT
22
Aug 14, 2013 11:42 AM
SeanM505
Cobb AccessPORT
Aug 24, 2012 09:52 AM
evo jason
Jan 11, 2012 09:01 PM
