4g63 carnage - Post Mortem
Old Oct 17, 2009 | 12:40 PM
cmj's Avatar
cmj
I thought I'd go ahead and post a few pics of the destruction of my block. The cause was a ruptured wastegate line, probably caused be removing and reinstalling it too many times. I had Evoscan running at the time and caught the destruction in a log. The car was making about 500whp and running E85. This tune was seeing a peak load of 410-414 at around 4700-5000-rpm and pushing 2800htz up top. The car was running a single modified walbro and Aquamist 100% meth. At the time of the incident the log shows a peak load of 460! @ 4700rpm in 4th gear, at point the afr climbed from the normal 11.8 to 12.7 and boom. The log shows knock at 4800rpm of 30, I'm not sure if it was det or just the sound of the rod snapping a whipping around. There is about a thousand pieces of piston bits left in the pan, the rest in on the freeway.
When I tore down the engine I found debris in the intake and exhaust manifolds.
E85 keeps pistons clean.
Old Oct 17, 2009 | 12:44 PM
huevosrancheros's Avatar
damn RIP
Old Oct 17, 2009 | 12:45 PM
eXtreme-Speed's Avatar
Sorry to hear that Time to rebuild...
Old Oct 17, 2009 | 12:55 PM
warp9's Avatar
Destruction, terror, & mayhem. No matter what Im always looking at my boost gauge whenever Im under full boost, you never know....
Old Oct 17, 2009 | 03:48 PM
crcain's Avatar
Do you have a map sensor logged to see what happened boost wise?
Were you on stock rods and pistons? What turbo?
Old Oct 17, 2009 | 03:57 PM
mdsevo06's Avatar
The thing about looking at guages, buy them time you see it, it's too late.
Time for a BR Stage III 2.0
Old Oct 17, 2009 | 04:18 PM
dxbtune's Avatar
From: I'm Canadian living and working in Dubai/Kuwait/Bahrain
Yikes, fun and games.
Old Oct 17, 2009 | 05:26 PM
cmj's Avatar
cmj
I was not logging boost. Boost was set to 30-32psi, it must have went over 40 for that kind of load.
Stock block
FP Red / cams
all the usual bolt ons
Mrfred's extended boost cut tables might have saved my block, too bad they came out a week after it happened.
Timing was set to 1 degree in the area where the block went boom
Old Oct 17, 2009 | 05:30 PM
Teal2nnr's Avatar
wow....shi*ty deals
Old Oct 17, 2009 | 05:33 PM
ak47po's Avatar
Those pics make me sad.
Old Oct 17, 2009 | 07:18 PM
JohnnyTSi's Avatar
Dang, that looks just like my failure from last month:
https://www.evolutionm.net/forums/ev...k-carnage.html
Sorry to hear about your bad luck.
John-
Old Oct 17, 2009 | 07:33 PM
Im assuming you're running stock internals?.......Based on your performance specs, sounds like the poor 4G63 hit its max.......Gotta love that iron block though.........I may post your thread link on our local forum so my tuner can read your story........Hope you plan a re-build.......Peace
Old Oct 17, 2009 | 08:20 PM
JohnnyTSi's Avatar
Stock Internals
Stock IX ported turbo
Magnus intake mani
PTE 1200s
modded WB255
S2 cams
fp springs
ETS 4" IC w short route pipes
Megan O2
full 3" exhaust
e85
a 4g64 block is almost done.
Old Oct 17, 2009 | 08:21 PM
JohnnyTSi's Avatar
Good Luck with your rebuild.
John-
Old Oct 18, 2009 | 04:46 PM
Jk's03EVO's Avatar
Some of the worst carnage I have ever seen. You literally cracked the block in half.
