help, this is tricky...
Old Oct 25, 2009 | 06:42 AM
TEAM ACE's Avatar
well sure, but a lifter is basically a mechanical part. so if it was a bad lifter the problem would be present all the time. thats what is really pushing me towards something electrical.
im gonna look over these service manuals now, but they only show pics and stuff. unless i didnt get to the tech part of it yet. ill post again later with more info.
Old Oct 25, 2009 | 10:52 AM
TEAM ACE's Avatar
this is confusing... electrically it could be the intake cam angle sensor, crank angle sensor, throttle position sensor, or air flow sensor.
i already replaced the air flow sensor and the oil control valve.
the ecu takes info from these four sensors, processes it and tells the oil control valve what to do.
it does not say specifically, but i believe with this sensor unplugged it is in the off or open position. meaning the engine runs at normal cam position. no advancing or retarding. so basically no fine tuning from the ecu to give me optimal emissions or fuel consumption...
so hoe the hell do i figure out where to start or what to replace or test?????? please someone with complete knowledge of this system help me...
i suck with electronics...
Old Oct 26, 2009 | 06:31 AM
TEAM ACE's Avatar
bump
Old Oct 26, 2009 | 07:39 AM
sk8terdude929's Avatar
Maybe ask Tephra or Mrfred they prob both know most about our ecus and if its possible this sensor is triggering something in the ecu. Sounds electrical to me since you can unplug it and it runs fine or its something in the mivec system since that sensor controls it.
Old Oct 26, 2009 | 08:39 AM
94AWDcoupe's Avatar
The 64 million dollar question is always "what did you replace on car to make this noise happen?"
is the mivec cam gear good? it may not be responding to oil pressure. it could be slapping back and forth.
several years ago a friend mine installed some 280cams. called and said the engine made a horrible noise by advancing intake cam just 2 degrees. he brought the car by and I was amazed at how loud engine got by advancing cam just 2 degrees. it sounded like valves contacting the pistons. I checked with boroscope and there was plenty of clearance. reverting intake cam to TDC and engine was dead quiet again. never did figure it out but I theorized there was some harmonic sound discharge with his particular setup.
Old Oct 26, 2009 | 09:15 AM
TEAM ACE's Avatar
well thats the thing, the bazillion dollar question answer is nothing. i put on a ets licp, p&p exhaust mani, and an 02 housing. had it like that for two months. then when i got to the tuner shop it took a crap in the parking lot...
Old Oct 26, 2009 | 09:36 AM
94AWDcoupe's Avatar
then my money is on mivec gear going bad
Old Oct 26, 2009 | 09:49 AM
Kilratio's Avatar
I had a similar problem on my 8, I was getting weird idle, false knock pulling timing. Was throwing cam position senser engine light and a few more to boot. I replaced all kinds of things till it finally took a complete dump. Turned out to be a bad coil pack. Pull your coils pack and plug wires out a bit and see if they are giving constant even spark. Not sure if this is your problem but it just reminds me of that.
Old Oct 26, 2009 | 09:53 AM
rolly1818's Avatar
Registered User
hmmm weird one.
run without MIVEC?
i agree with the others on your intake cam gear.
Old Oct 26, 2009 | 11:56 AM
TEAM ACE's Avatar
so your not implying that the actual gear is bad, just the internals of the gear? well is there any way to check?
i know its not fixed, but at least im finally getting a direction to go in.
can anyone tell me why there is not a troubleshooting guide in the service manual i have downloaded?
Old Oct 26, 2009 | 01:43 PM
rolly1818's Avatar
Registered User
i dont know for sure where it is in the manual. search in the pdf for MIVEC or inake or cam
that should find it.
other than that its time to get dirty - start disassembling.
Old Oct 26, 2009 | 06:45 PM
1d10t's Avatar
Originally Posted by 1d10t
Maybe if it controls the Mivec cam gear, maybe that assy is faulty. When it gets oil pressure maybe its loose or something
Check the Mivec cam gear
This is my guess.
Maybe you can test it with compressed air
Old Nov 16, 2009 | 06:45 AM
94AWDcoupe's Avatar
any update?
Old Nov 20, 2009 | 04:36 PM
TEAM ACE's Avatar
no, sorry. i have been educating myself for a while on these issues, and im broke. gotta make those dollas, but when i get to it i will update
Old Nov 21, 2009 | 05:38 AM
barneyb's Avatar
Could be you have a some wiped balance shaft bearings.
Live4Redline
Jul 17, 2024 07:09 AM
xexitenglishx
32
Apr 13, 2013 11:44 PM
criptballer
Jun 30, 2010 12:21 PM
TEAM ACE
17
Aug 13, 2009 10:25 AM
Nomad4g63
34
May 11, 2009 05:49 AM
