Help choosing cams! HKS 272 to ???
Old Oct 22, 2009 | 10:55 AM
  #31
jmelocik's Avatar
Originally Posted by mspandl
gsc s2's with springs and retainers!
Check the thread I linked to earlier, the GSC S2's are great cams for stock turbo cars. Red, GT30, GT35 and larger would probably gain more from larger cams like the Kelfords and Cosworth M2's.
Josh
Old Oct 22, 2009 | 10:56 AM
  #32
dsmfan95's Avatar
Keep in mind that, like scheides said, on the AMS test they used a ported head. A few gurus on this site have said that over 10.5mm of lift will be wasted with an unported head. That's why the HKS series cams performed so well with a completely stock head, at least on an Evo 8.
Old Oct 22, 2009 | 11:01 AM
  #33
scheides's Avatar
EvoM Moderator
I ran my kelfords on my unported head and they made a difference. Still worth upgrading.
Old Oct 22, 2009 | 11:09 AM
  #34
jmelocik's Avatar
Originally Posted by scheides
Remember, those gains are on a 35R, ported head, and IIRC fairly high boost. Pump gas and smaller turbo, less mods, don't count on 44whp It's all about percentages.
I mentioned them before and think its worth mentioning again, I went with the GSC Beehive springs that use the stock retainers. I don't think there is a better bang/buck out there, esp if you are on stock bottom-end and don't plan to rev over 8500-ish.
http://www.maperformance.com/gsc-pow...retainers.html
$220 www price, I'm sure they can be had for a bit less than that if you ask nice
All testing was done at 22psi, pretty realistic for most of us, not for that setup though. You are correct in the fact that it was a ported head and AMS VSR manifold though.
Josh
Old Oct 22, 2009 | 11:17 AM
  #35
Strictly Modified's Avatar
Originally Posted by EVO8GIXXER6
You wouldn't happen to have a dyno graph of the BR spec cams would you? How is the driveability with them? Idle rough? Lopie? Etc?
Not on hand i dont no, they are lopie cams, driveability is not bad at all.
-Cisco
Old Oct 22, 2009 | 11:22 AM
  #36
dsmfan95's Avatar
I went from hks 272s to gsc s2's (original style), and while it shifted my powerband to the right some, I didn't pick up hardly any peak power.
Old Oct 22, 2009 | 11:42 AM
  #37
colonelfox's Avatar
I know it's not a popular choice but I went from HKS 272's to Comp 280's and got a substantial seat of the pants increase and over 60WHP gain in Evoscan after some AF changes. No real dyno numbers yet, but I'm very happy and they were reasonably priced.
Old Oct 22, 2009 | 12:21 PM
  #38
zedevo's Avatar
I have the BF 272's + FP Be heave Sprins with Stock Retainers + Manley Valve ...
+1 for the BF cams ... Much better than the HKS ... . I have the HKS 272's and now the BF .... Awesome Cams ...
Old Oct 22, 2009 | 12:22 PM
  #39
CMB's Avatar
CMB
Excellent information, I will be going with the Kelfords on a stock head until I rebuild my motor and the cams will shine even moreat that point. Thanks
Old Oct 22, 2009 | 12:26 PM
  #40
CMB's Avatar
CMB
Originally Posted by jmelocik
Thanks! I'm trying. BAPS (Ballistic Armor Protection System) saved my a$$ the other day, literally!!! We were flying in to pick up some injured Marines and an insurgent was shooting at us from a heavily grown over field. Hit the aircraft several times, one of which was directly under my seat (right crewchief/ door gunner seat). I thought I was done! checked my butt, no blood, checked my buddy, no blood, all is good! The ground guys called in some Marine Cobras and I'm sure they made that guy have a very bad day!
Josh
Man im sure youve got plenty of stories to tell! I cant express enough how proud I am to be an American and even prouder to have guys like you protecting our freedom!
Old Oct 22, 2009 | 12:46 PM
  #41
RockmanX's Avatar
you doing spring retainer upgrade supertech?? heck just buy a br stage 3 head and call it a day haaaa.
Old Oct 22, 2009 | 04:39 PM
  #42
EVO8GIXXER6's Avatar
Exactly^^^^^
Old Oct 22, 2009 | 05:16 PM
  #43
CMB's Avatar
CMB
It did run through my mind!
Old Oct 22, 2009 | 06:16 PM
  #44
whitemonster's Avatar
i would definately go with the kelford 272's in the ams cam shootout kelfords made the most power they have the same lift and duration as the cosworth m3's
Old Oct 22, 2009 | 06:51 PM
  #45
project_skyline's Avatar
A very good recommendation. Also the Cosworth M2's, which have the same lift and profile, will give the same result. I switched from HKS 272's to the M2's and have never looked back. You will need to upgrade your springs and retainers as RockmanX stated. Also I recommend you read the AMS cam shootout for the best cam for your application and driving style/rev range. Check it out here: https://www.evolutionm.net/forums/ev...-cam-test.html
Josh
Kelford will give more power then cosworth M2's.
