4g64 block with 4g63 trans
Old Oct 25, 2009 | 02:00 PM
evo5killer's Avatar
Hi, some one know or try to install a 4g64 block to a 4g63 transmition it fit easy or have to do some mods, needs some help.
Old Oct 25, 2009 | 02:22 PM
justa4banger's Avatar
it will bolt straight up
Old Oct 25, 2009 | 02:26 PM
NickieBlaine's Avatar
yup just put mine in lat week. everything bolted right up no problems.
Old Oct 25, 2009 | 02:49 PM
crcain's Avatar
Yep no problems.. I run Evo VIII trans with 4G64 no probs.
Old Oct 25, 2009 | 03:04 PM
Sully 18's Avatar
same with me same with me.... just got it going no problems
Old Nov 5, 2009 | 06:06 PM
dragers's Avatar
from what car do you recomend to get the 4G64 block?
I have tried a couple of 4G64 and they dont have the exact same bolt pattern as the 4G63 evo 9?
Old Nov 18, 2009 | 12:41 PM
Sully 18's Avatar
not sure.. turbo trix got it
Old Nov 18, 2009 | 12:44 PM
3gturbo's Avatar
Any 2000+ eclipse is your best bet
Old Nov 18, 2009 | 12:45 PM
JohnnyTSi's Avatar
4G64 blocks that bolt direction into the Evo 7-8-9's can be found in the following:
Mitsu Eclipse 2000 - 2005
Mitsu Galant 1999 - 2003
Mitsu Montero 2000 - 2003 (not sure on the years)
Chrysler Sebring 2001 - 2005
Dodge Stratus 2001- 2005
Hyundai Sonata 1999-2001 (not sure on the years)
However it should be noted that some of the non-mitsu blocks have some small differences (like the oil dipstick tube being located at the front of the block).
John-
Old Nov 18, 2009 | 01:32 PM
Sully 18's Avatar
mine is in stock place.. just had to tap for the mivec oil line
jos
May 8, 2017 08:06 PM
senate6268
128
Sep 3, 2015 10:44 PM
wesleylawson6
Lancer Engine Tech
Jan 7, 2015 05:27 PM
PHILLY EVO
Mar 7, 2009 08:43 AM
SeanC
Nov 27, 2007 03:21 PM
