One wheel on air and the other 3 don't move
Old Oct 27, 2009 | 01:07 PM
dinopunx's Avatar
Hello,
I own a Mitsubishi EVO VIII 2003. My car doesn't have ACD or AYC. It has VCU. My house driveway has some inclination and sometimes, depending on the angle in which I try to enter the driveway, one of my back wheels lifts from the ground and the other three remain completely on the ground. Every time this happens only the wheel that is on the air spins while the other 3 that remain on the ground don't move at all.
Can someone tell me if this is normal or not please. If not, can someone tell me the solution to fix the problem. Thank you for your time.
JRY.
Old Oct 27, 2009 | 01:22 PM
charon2123's Avatar
So, do you just stop moving when this happens? If you continue to move forward while tripodding, I wouldn't worry too much about it; however, if you still feel this is an issue, take the car to a mechanic or dealership to check it out.
Old Oct 27, 2009 | 03:42 PM
Raif's Avatar
its normal. My driveway is the same way. Every single awd car that I own does the same thing. Talons and evos.
Old Oct 27, 2009 | 05:03 PM
barneyb's Avatar
Try it with the emergency brake on a little.
Old Oct 28, 2009 | 02:47 PM
dinopunx's Avatar
Only the wheel on the air spins. The other 3 wheels don't move at all. A friend told me that maybe my rear differential is not working. I'll check on that. Thanks for your help.
Old Oct 28, 2009 | 03:35 PM
barneyb's Avatar
The reason I said to try it with the emergency brake on a little is that the type of limited slip rear differential these cars have requires some torque to lock. I used to drive a Trans Am with the same type of rear differential and I always had to apply the emergency brake to get moving in the snow.
butters149
Mar 26, 2014 07:08 AM
Alex Rodriguez
For Sale - Wheels / Tires
24
Mar 12, 2014 11:32 PM
Nasty Evolution
Nov 6, 2011 09:34 AM
Karass
Apr 9, 2009 11:53 AM
osunick
Feb 22, 2008 04:50 AM
