3-wheel up driveway bad for diff?
I was just wondering if 3 wheeling it up a driveway is bad? my driveway is kind of sleep so I usually have to go at an angle, problem is when I do that most of the time only three wheels touch the ground, the fourth is usually the passenger rear wheel up in the air. sometimes i would try to grab a little speed and let it coast on up, but sometimes I go up slowly.
Just wondering if this is bad for the differentials?
It does not cause any immediate harm to the differential. At most it would cause irregular wear over time, but nothing that would constitute damage. I would park on the side instead of the driveway until you find a solution to fix the uneven gradient of the driveway. How is your current ride height ?
-pal215
-pal215
a differential allows opposite wheels to rotate at different speeds. the diff just spins without load if your going in a straight line on a normal road. the only times a diff will wear is during a turn where the differential will be under load or when your driving with a tire on ice or in a big puddle and is spinning at a different speed than the opposite tire (similar to a turn).
xexitenglishx
11
Dec 22, 2010 05:08 PM
g6civcx
16
Oct 18, 2004 05:55 AM
