Tune the EVO8
Old Oct 21, 2003 | 01:46 PM
Yaroslav's Avatar
Tune the EVO8
Tell me how much HP will gain with this parts?
1) B&B 3ich Turbo Back Exhaust
2)HKS intake or RMR
3)XEDE
4)blow off
5)silicone hoses
6) Clutch kit
7)PWR Intercooler
8)PWR Radiator
9)Walbro Fuel Pump
10)JIC Stainless Header
11)
And do i need a Grounding kit, HKS Camshafts,HKS Cam Gear ?
Thanks
Old Oct 21, 2003 | 01:58 PM
SAEVO's Avatar
right off the bat that setup will not work, No intakes with XEDE. You need to take that off the list or rethink if you want to use the XEDE.
Old Oct 21, 2003 | 02:24 PM
Yaroslav's Avatar
why so?
Old Oct 21, 2003 | 02:29 PM
Eric Lyublinsky's Avatar
Not Ture, you can use Xede with an intake but you will have to have the car tuned for that intake. There are no base maps yet for intakes as far as I know.
I made 292 hp with a Xede and B&B cat back.
So you should be in the 300 rang with those mods.
Intake is not worth much if anything at all.
Old Oct 21, 2003 | 02:55 PM
QuantumEVO's Avatar
Shiv always says "no intakes" so he has no base maps for them, but base maps aren't "plug and chug" anyways; you should tune it regardless.
A few notes on your mod list; coat the manifold with Jet Hot or equivalent (turbo cars don't have a header) and get a good set of IC piping instead of silicon hoses. Cams and/or gears will add power as well.
Mark
www.Quantum-Racing.com
Old Oct 21, 2003 | 03:05 PM
DynoFlash's Avatar
we have no issue with intakes at all
Old Oct 21, 2003 | 08:23 PM
shiv@vishnu's Avatar
Yes you do. You just don't know it.
Shiv
Old Oct 21, 2003 | 08:25 PM
Marcus84's Avatar
lol
Old Oct 21, 2003 | 08:30 PM
Epidemic's Avatar
lmao, ya shiv you let him know whats up....since he does'nt know what's up.....or.......damn i'm confused
Old Oct 21, 2003 | 08:34 PM
MrBubbler's Avatar
yea intakes suck i love my big black box of power... dam the short ram man
Old Oct 21, 2003 | 08:57 PM
Jadiem's Avatar
so basically, get an intake for looks... if so, damn thats a first...
Old Oct 21, 2003 | 09:06 PM
Ryanmcd2's Avatar
In Timeout
LOL, Come on big Al is the one stop shop, once his dynoflash blows your car up he can represent you when you go to court to sue them for the repair. Al is smarter then we think he makes money on both sides
Shiv
Old Oct 21, 2003 | 09:07 PM
DynoFlash's Avatar
Shiv
Shiv - we know very very well about the MAF signal fluxuations and misreadings from the cheap aftermarket air filters
We have seen the results on the dyno
Basically - we had two choices - either we could refuse to tune cars with those air filters - which are very popular
OR - we could do our best to work with what the customer provided - and thats what we have done
Using the superior reflash technology and tuning know how of dyno flash we have been able to very sucessfully tune cars even with the most stuborn air filters
Frankly - our initial tests with the stock evos showed NO gains from air filters what so ever - even removing the air filter made no power
the effect that people see with the air filters is from hearing more noise and from the maf signal getting thown off causing the cars to run lean
we have seen otherwise stock cars running dangerously lean and detonating like crazy with air filters
if I had a mildly modified or stock evo I would run the stock filter box and bov
The fact is that the most popular modification for evos seems to be air intakes and bov's - lucikly we have been able to tune around the shortcommings
Old Oct 21, 2003 | 09:26 PM
DynoFlash's Avatar
BTW - you see it once again with Shiv - soon his reflash will be out - it will be the newest and greatest thing and then the great Exede will be a thing of the past like the ole' vishnu unichips for wrx
Old Oct 21, 2003 | 09:59 PM
Al,
Since you agree that intakes can cause MAF sensor misreadings, how do you account for such misreadings at anything other than the full throttle/full boost condition you dyno tune with? I wasn't aware the Dynojet, or any inertial dyno, was capable of supporting the steady-state load/rpm mapping required to compensate for such transient sensor errors. One doesn't always drive at full throttle, right?
Also, keep in mind that I do not refuse to dyno cars with intakes. I simply suggest that those running aftermarket intakes don't rely on the baseline XEDE maps to provide suitable fuel/spark mapping. Custom tuning is necessary when aftermarket intakes are installed.
Cheers,
shiv
