Car acting weird under boost!
Old Oct 28, 2009 | 03:42 PM
aguita's Avatar
My car that is equipped with a 50trim turbo when using low boost 14psi the car runs fine but when running 20psi is not pulling so hard and when you go on 3rd gear the car like it goes off boost (like it holds)and then pull again.. what can be the problem?
Old Oct 28, 2009 | 04:42 PM
MR. EVO MR's Avatar
Plug gap?
Old Oct 28, 2009 | 07:30 PM
aguita's Avatar
I don't think is plugs bc this only happens under high boost,but last time I checked them they where very open,also I notices that I have a manifold leak where it meets the turbo u can feel the leak if you put your hand in front of it,could this be part of the problem,ill change plugs,where should the gap be?but I don't understand why this happens only on 3rd gear there is where you feel that the car really holds you down
Old Oct 29, 2009 | 03:33 AM
MR. EVO MR's Avatar
dont go bigger than .024, dont change the plugs just regap them first and see what happens
Old Oct 29, 2009 | 08:59 AM
aguita's Avatar
bump
Old Oct 29, 2009 | 09:07 AM
silverIXMR's Avatar
bad clutch? when mine went it only slipped during spool up and the boost would flutter during peak torque then it would go again
Old Oct 29, 2009 | 09:37 AM
aguita's Avatar
I launch this car very hard and the clutch holds like it should..
Old Oct 29, 2009 | 10:10 AM
aguita's Avatar
and the sign is that the car when you go into 3rd gear and go into boost ,it holds the power down ,not a sign of bad clutch
Old Oct 30, 2009 | 12:20 PM
aguita's Avatar
bump
Old Nov 2, 2009 | 05:30 AM
aguita's Avatar
up
eddy5201314
Feb 3, 2017 04:37 PM
TOAjosh
May 22, 2012 04:55 PM
GSX 911
Aug 9, 2011 08:43 PM
5LEEPERISAH23I
Apr 16, 2010 08:07 PM
procircuitmike
Jan 8, 2008 07:51 PM
