Kasey at MAP's 2.4 Hybrid Build
So I have a question that I can not seem to find the answer too. When doing the 2.4 block with evo head, why do you have to use the Evo water pump with adaptor? Why can you not use the 2.4 water pump?
The 2.4 water pump use's the same bolt holes, but is just a little bigger in certain ares of the water pump. You do need a adapter plate and 4g64 water pump gasket with your 4g63 water pump with gasket.
Soon as he gets some miles on the engine, we will get some dyno numbers up. He will be back in a week and I'm sure he will be ready to get it on the dyno!
Thanks,
Adam
Thanks,
Adam
