Kasey at MAP's 2.4 Hybrid Build
Old Jan 21, 2010 | 09:21 AM
  #46
EvoPower81's Avatar
Originally Posted by maperformance
I agree Hopefully with the red and 35 psi I can make close to 600hp and 600ftlbs. I think that would be a fun set-up also.
Sounds good Kasey. Do you think the Red is capable of those figures?
Old Jan 21, 2010 | 09:25 AM
  #47
EvoPower81's Avatar
Some more stuff came in today!
Custom Grind Cams
GSC Beehive Springs and Retainers
Power Enterprise 87mm bore Head Gasket
Has anyone tried the OEM 4G64 head gasket from the DOHC motor? From what I see it looks like good quaity
Old Jan 21, 2010 | 09:51 AM
  #48
bbyevo8u's Avatar
Is the 2.4l more reliable then 2.3l 4g63?
Old Jan 21, 2010 | 09:58 AM
  #49
20gmr's Avatar
hey random question I know, Did the girdle from your old motor get damaged. I have an evo 4g63 that needs a girdle... long story. If it is salvageable pm me I am very interested.
Old Jan 21, 2010 | 10:12 AM
  #50
ChrisCarey's Avatar
Yes as the 4g64 block is 6mm taller than the 4g63 so you can avoid the wristpin and sideskirt modifications to the pistons that are necessary when using the 100mm crankshaft into the 2.0l block
Old Jan 21, 2010 | 10:39 AM
  #51
RAbishi's Avatar
good looking build
Old Jan 21, 2010 | 10:54 AM
  #52
xRoguex's Avatar
The 2.4 + Red is a fun combo.
I would know. =)
Old Jan 21, 2010 | 10:57 AM
  #53
maperformance's Avatar
Originally Posted by RAbishi
good looking build
Thanks!
It did get damaged and it is long gone, sorry about that
I did look at it, but I not sure if I want to take that chance with my motor so I just went with the PW.
Old Jan 21, 2010 | 01:21 PM
  #54
Hopefully close to it if not.
Old Jan 21, 2010 | 01:44 PM
  #55
EvoPower81's Avatar
If so RED it is for me!
  #56
scheides's Avatar
EvoM Moderator
Info on the cams plz
Looks good man, get this thing back together!
Old Jan 21, 2010 | 01:54 PM
  #57
Originally Posted by scheides
info on the cams plz
looks good man, get this thing back together!
272 272
Old Jan 22, 2010 | 06:51 AM
  #58
EvoPower81's Avatar
Keep the pics coming
Old Jan 22, 2010 | 07:25 AM
  #59
scheides's Avatar
EvoM Moderator
272 272
c'mon, a little more than that! Are they from GSC? Big lift, little lift, what?
Old Jan 22, 2010 | 08:15 AM
  #60
They have a .246 lift with a peak lift of 10.8. Should be a good cam for a stroker.
