Why We Leak Test Each Intercooler! and HOW!
Old Nov 4, 2009 | 04:49 PM
THUB's Avatar
Hopefully this doesn't start more bickering, but how significant is a 4 PSI leak over 15 seconds? would anyone ever notice a leak this small? Obviously less leaks are better than more, but Would this type of leak even add up to 1 load point error in a standard MAF equipped car? I guess I'm just stirring the pot. But I am curious.
Old Nov 4, 2009 | 05:00 PM
Gary 805's Avatar
ETS is Awesome.. I still have the same intercooler from 2004 i got when they were being sold through HPF..
I love it.. Cant go wrong with ETS at all.
Old Nov 6, 2009 | 09:43 AM
OneEyedJack's Avatar
Well that's a static leak (pressure drop) It correlates to some mass flow (losing X "air molecules" per "minute") depending on the internal volume of what you are leak testing and what its full of (air in this case. Also temperature etc matters but thats beyond the point...)
It also matters what the pressure was initially... a 4 PSIG drop out of a volume pressurized to 1000 PSIG is pretty insignificant, but 4 PSIG out of 20 PSIG is a 20% loss of air mass in 15 seconds, or an 80% loss over 1 minute if the leak continues at the same rate (the relationship is linear assuming ideal)
Thinking about it relatively though... this loss equates to some volume/time as well (at atmospheric pressure once it's leaked out of the system) The thing to do would be to compare that volume flow (leak) rate to the flow rate your system (engine) is seeing at a given RPM.
Hard to tell mathematically without knowing volumes and flow rates!! Only real way for sure is to test it. Which requires someone with experience (a tuner!!!)
Ooops, I definitely didn't answer your question. Just a bunch of techno-babble. And for that, I apologize.
Old Nov 18, 2009 | 11:29 AM
ETS Michael's Avatar
Bump for the guy on the phone who wanted to know how to pressure check his intercooler!
Thanks,
Michael
Old Nov 18, 2009 | 03:22 PM
Ted B's Avatar
Originally Posted by ETS Michael
From our experience the Majority of the Garrett cores leak from the factory and require resealing.
I have a Garrett Race core, which is used by at least a few popular vendors here. I have also isolated a couple of small leaks, which appear to be originating at the end (inside the end tank), and have worked their way around the end tank weld.
Garrett glues the sections together. So long as the glue at the end of the core seals across the width of the core seams, from weld to weld, it's ok. It seems that with some expansion/contraction due to changes in pressure/temp, that can compromise these joints, allowing pressure to work its way from the end tank, through the core seams, to the outside.
I had Drifto remove an end tank, where the slight seams in the end were visible. I carefully sealed them with JB Weld, but it is something of which to be aware.
The Garrett Race core is a very efficient piece, but apparently, isn't without potential faults. In my case, the leaks were small, but several small leaks is like one larger one.
Old Nov 18, 2009 | 04:18 PM
Your exactly right. I'm not a big fan of JB Weld, but it's 100x better then glue
Michael
Old Nov 18, 2009 | 05:32 PM
EvoRob22's Avatar
Perrin test their intercoolers at 120PSI!
http://www.perrinperformance.com/pro...ory=39&model=3
Its always nice to have the insurance of quality when buying a product . I never thought Garret has such a problem with their intercoolers.
Old Nov 18, 2009 | 05:44 PM
MR. EVO MR's Avatar
is it necessary to pressure test the fmic sometimes, or is it a 100% maintenance free product?
i have a turbo xs
Old Nov 18, 2009 | 05:53 PM
EvoRob22's Avatar
i have a turbo xs
Not necessary, but it never hurts. I would check it occasionally. You never know what rocks in the road can do it it.
Old Nov 22, 2009 | 09:40 AM
2StepsAhead's Avatar
This goes for Garret cores with ETS end tanks too right?
Old Nov 22, 2009 | 11:28 AM
JDavenport's Avatar
This is interesting. I used to be a mfg engineer at a company that made heater cores, radiators, AC condensers and evaporators. They were all made of clad aluminum. The clad layers were designed to melt at a slightly lower temp than the core material.
So these various heat exchangers were mechanically assembled and sent through a braze oven which would melt the clad layers forming the seals at joints and final mechanical rigidity.
For condensers and evaporators, our final leak test was to place them in a vacuum chamber, pull hard vacuum, pressurize them with 300 psi helium and activate a mass-spec leak detector looking literally for molecules of helium escaping.
I'm surprised any modern mfg of this type of unit would have any kind of noticable leak rate issue.
Old Nov 22, 2009 | 11:47 AM
F0RSAKEN's Avatar
I'd bet the differences between that process and what is or isn't used on intercoolers for cars would be what exactly is leaking out.
A small leak in an intercooler is really non-critical to someones health, and if it's small enough, it probably isn't critical for the engine either. If an AC condenser has a small leak, it can be harmful to someones health.
Old Nov 23, 2009 | 03:31 PM
We won't let the intercoolers leave with a leak. We fix all the Garrett cores before they leave.
Michael
Old Dec 10, 2009 | 02:52 PM
Just spoke with a guy on the phone about a boost leak. Here is the thread.
Thanks!
Michael
Old Dec 15, 2009 | 07:36 AM
rgar's Avatar
I understand that you fix the leaks(ETS) but are you likely to develop new ones over time?
