Why We Leak Test Each Intercooler! and HOW!
Recently we posted about why we leak test each intercooler. The post was locked due to a couple vendors/customers bickering back and fourth.
We at ETS feel it's our duty to our customers to pressure check each intercooler to 35psi-40psi before it leaves our facility. You may ask why would you need to leak check an intercooler?
If you purchase a Garrett intercooler you get a little note in the box that looks like this. From our experience the Majority of the Garrett cores leak from the factory and require resealing.
When we build our ETS intercoolers we have them pre pressure checked, then after welding we pressure check again to ensure that we have no leakage.
If you need to pressure check your intercooler. Here is a link from the DSM days that shows how to build a low budget leak tester.
http://www.vfaq.com/mods/ICtester.html
This is a good test to do after installing intercoolers pipes, intercoolers, blow off valves, etc.
Any questions, let me know!
Thanks!
Michael
Thanks!
Michael
No it can't. Some of the leaks are deep within the tube to header area, toward the middle of the core. No way to get weld to them. We have a method of ensuring a 100% leak free heat exchanger for our industrial bar and plate oil coolers.
All bar and plate mfgrs have leakers here and there.
If you have a leak, clean the core, lay it flat on a bench/floor and use super glue on it.
thanks!
Michael
Michael,
We have built a leak test jig for cores using a thin rubber gasket, two plates with long bolts to clamp the core. However sometimes when the header bars are a little uneven the gasket won't seal properly. There are some cores that we throw in the recycling bin because it's cheaper to scrap the core than it is to put all the labor into building a cooler, only to have to cut the tanks off because of a leak.
Michael,
Thanks for sharing!
Michael
I have the AMS intercooler. I did a boost leak test with the motor at TDC. It took 59 seconds to go from 20 psi to 10 psi. There was a small leak from the bov and a very small leak from the throttle body. I have the works shaft seals.
