MBC users thoughts?
Old Nov 5, 2009 | 06:21 AM
PlanoEvo's Avatar
MBC users thoughts?
After talking to a fellow friend last night about how much he loves his MBC I am rethinking the whole EBC thing. Anyone care to chime in on why they love their MBC and overall feelings.
Old Nov 5, 2009 | 06:22 AM
MR Turco's Avatar
do you already own an EBC?
Old Nov 5, 2009 | 06:23 AM
Kracka's Avatar
Easier, cheaper, smoother boost curve
Old Nov 5, 2009 | 06:29 AM
Ginglingston11's Avatar
wait a sec, if you already have an ebc you would be a moron to switch to a mbc. mbc are great for the price and they are simple to install. they work very well otherwise no one on here would ever of had one. an ebc is simply the best. it holds your boost 10x better than any mbc ever could. but if your looking to buy a mbc or ebc then it is all up to you. what kind of power are you looking to make? what are your future goals? do you have the money for an ebc?
all those questions you have to answer yourself. i personally am still using a mbc. (i dont plan on switching to a ebc until i switch to a AEM EMS) in facts its the SAME exact mbc i have had and been pushing over 20 psi for over 6 years on my DD's. like i said mbc work very well, but they just dont have some of the advantages ebc have.
good luck with your choice
Old Nov 5, 2009 | 06:34 AM
PlanoEvo's Avatar
have a 3 port and a mbc neither are on the car but one will be very soon. seems like a lot of work to get the 3 port dialed in and Ive heard its not that consistant.
Old Nov 5, 2009 | 06:36 AM
Kracka's Avatar
I beg to differ. I had a MBC on my Evo, switched to a GM BCS, then eventually went back to a MBC and couldn't be happier.
Old Nov 5, 2009 | 06:38 AM
MR Turco's Avatar
EBC should yield slightly faster spool and better top end.
Old Nov 5, 2009 | 06:41 AM
Kracka's Avatar
I noticed the exact opposite on my car. Response is much improved with the MBC back on again and the car also spools faster (the new Tephra v7 should improve upon that a bit though). On my car, remember its a IX, to get the most power with pump gas I was actually having to taper the boost down basically mimicking the taper a MBC has since the car preferred timing over boost in the upper RPM's.
Old Nov 5, 2009 | 06:49 AM
MR Turco's Avatar
I have always seen 1-200 rpm quicker spool going from MBC to gm 3-port. I think GST has a bunch of data posted somewhere. Logically it makes sense, you are keeping the WG completely clamped instead of progressively opening like on a MBC.
Old Nov 5, 2009 | 06:50 AM
SyZyGy1394's Avatar
You sure it isnt just the way you have your boost control set up on your rom? Also I kinda hate how the colder it gets the more boost it will make on a MBC. I do know why, I just wonder if moving the MBC closer to the block will make more consistent boost versus varying outside temps. hmm...
Old Nov 5, 2009 | 07:01 AM
Kracka's Avatar
My GM BCS was properly setup and I tried it both load-based and with a JDM 3.3-bar MAP sensor.
GST's data is what convinced me to try it in the first place, I just saw none of the benefits but all of the drawbacks on my car. I gave it a good long chance, had it on my car for about a year, and did everything imaginable to get it tuned in properly but was just never happy with it.
Old Nov 5, 2009 | 07:10 AM
MR Turco's Avatar
i totally understand your frustration, esp come winter time. I am very much looking forward to getting on v7 mainly for weather correction. It is tough, as someone who is constantly tuning their car i don't really mind but typically recommend a MBC for those who don't want the hassle.
Old Nov 5, 2009 | 09:35 AM
SyZyGy1394's Avatar
So how difficult is it to do ecu controlled boost? I've been tuning my car by myself and after a few weeks of messing around, its gotten pretty damn easy.
Old Nov 5, 2009 | 09:45 AM
thats the first time i have ever heard of that
Old Nov 5, 2009 | 10:10 AM
FJF's Avatar
FJF
Much of the cold weather spiking is due to the spring inside the MBC changing its response as the metal gets colder. My MBC is mounted to the radiator. As the rad comes up to temp, so does the MBC. As such, I see little variance in boost levels - ~.5PSI from 30F-90F according to my logs. FWIW, I can't take credit for the idea. Em, from STM, installed it in that location for this very reason and he was right.
