Who can explain?
Old Oct 21, 2003 | 02:50 PM
Yaroslav's Avatar
Boost Controller
I installed my apexi avc-r BC and don`t know how to manage with it. Can you help me? Which settings to set and where?
Thanks a lot
Old Oct 21, 2003 | 02:57 PM
1QWKEVO's Avatar
does that unit use a set and gain setting?
Old Oct 21, 2003 | 03:42 PM
Yaroslav's Avatar
how can i set boost 1.3?
Old Oct 21, 2003 | 09:00 PM
bs's Avatar
bs
go to settings and boost level and select 1.3 bar. you will have to set your duty cycle as well.....mine is at 63%. you will also need to mess with the start duty and feedback speed. my feedback speed is set for 1 for all gears.
start duty
1st +6
2nd +3
3rd 0
4th -4
5th -8
hope this helps
Old Oct 22, 2003 | 10:07 AM
Yaroslav's Avatar
Thanks a lot!
Can you explain me what is start duty and feedback speed?
Old Oct 22, 2003 | 12:43 PM
Yaroslav's Avatar
Who can explain?
Apexi BoostController avc-r.
Can someone explain in detail what is it and which settings to put?
ETC.
1)car settings-car select CYL SPD THR
2)GEAR JUDGE?
3)GRAPHIC SEL?
SETTINGS
1)BOOST/DUTY?
2)SCRAMBLE?
3)NE-POINTS?
4)F/B SPEED?
5)LEARN-GEAR?
6)START DUTY?
HELP ME PLEASE!
THANKS A LOT!!!
Old Oct 22, 2003 | 03:11 PM
bs's Avatar
bs
http://www.apexi-usa.com/electronics...aloverview.asp
this has a great explanation on what the features of the avc-r do. basically the feedback speed determines how fast the controller will attempt to regulate boost. to high of a value however can cause oscillation.
start duty adds or subtracts duty to the solenoid depending on the gear. this is valuable in keeping a car from overboosting in a higher gear or for adding duty say in first gear when you are trying to get the turbo spooled.
Old Oct 22, 2003 | 03:25 PM
1QWKEVO's Avatar
man i hope thats not how you tune your car ...
sit down and read the literature it's very helpful.
Old Oct 22, 2003 | 03:28 PM
bs's Avatar
bs
once again here is all the info you need to know
Old Oct 22, 2003 | 03:29 PM
bs's Avatar
bs
i should add that if you don't know what you are doing this is a fairly scary boost controller to be screwing around with. in other words take it to a shop
GSXPimp
Apr 12, 2016 06:10 AM
wolf213
Jun 15, 2010 09:16 PM
jhanksevo
Nov 21, 2007 04:13 PM
Aloy
Jun 30, 2004 05:22 PM
