fp-red w/80mm cover or fp-blk??
Old Nov 11, 2009 | 12:53 PM
bbyevo8u's Avatar
i'm ready to buy a turbo but dont know if i should get the red or black?
its going to be tuned for 93oct i'm shooting for mid to lower 400whp-450whp with my mods in my sig and the turbo & injectors.. at first i was going to buy the bbk full but then i changed my mind i want something a little bigger so i was going to buy the red but now that the black is out would it be better to buy the black since there the same price
just need a lil help before i buy
Old Nov 11, 2009 | 01:02 PM
Aniel's Avatar
I always say go with the bigger so you wont regret later We have both in stock give me a call
Old Nov 11, 2009 | 01:06 PM
RockmanX's Avatar
they are not the same price fp red 1799+ shipping fp black 1999+ shipping. You can also buy used reds for cheaper. The black is really more geared towards a built motor. running it on 25-30 psi is not going to show its true potentail. you will need to push 35-40+ psi on it to get the true power out of it. its also 200 rpms laggier then a red. so if you dont plan on doing any of that the choice is made fp red on 30-32 psi of boost and be happy. also double pumper is needed and according to new reports a modified oil pan might be need for the black as well. so its more of a expensive indever then to just "bolt it on"
edit i can see getting the black now to get it over with if your going to be building the longblock real soon etc. then yea get the black so you already have to turbo in place for sure but if thats not in the cards for awhile the red will do just fine.
Old Nov 11, 2009 | 01:10 PM
gsr0801's Avatar
What about upgrade?? Is FP upgrading the Red to the Black as yet?
Old Nov 11, 2009 | 01:14 PM
RockmanX's Avatar
they did mine check the other thread for you answers i think binky is thread starter
Old Nov 11, 2009 | 01:15 PM
Aniel's Avatar
Well of course i meant to say thats my opinion since i see that happen everyday at my job here, also keep in mind $1799 plus you need the Gen 2 feed line thats $150 = $1949 for the Red The FP Black already comes with the specific feed line so theres no confusion with that
Old Nov 11, 2009 | 01:17 PM
mt057's Avatar
The modified oil pan would be recommended to any car running over .x amout of G's during launch which is probably alot of big hp evo's. It is not a problem only associated with the black. Many cars have already been exceeding the limit and encountering this problem but it is only for a short period of time.
With meth or E85 you can easily hit your power goal with a red.
Although I am feinding for a Black...
Old Nov 11, 2009 | 01:18 PM
RockmanX's Avatar
YO aniel are the blacks already ported?? if not how much to get that added mine is still there as you know and im not worried about it but i prefer it ported before it leaves the mothership.
Old Nov 11, 2009 | 01:21 PM
bbyevo8u's Avatar
ok i'm def going with the red!!
should i get the "oil line" feeder, i dont plan on boosting past 30psi but should i get it to be safe?
thanks for the help
Old Nov 11, 2009 | 01:27 PM
bbyevo8u's Avatar
i plan on running the turbo with only pump gas as my daily driver do you still think i should go with the black?
thanks
Aniel's Avatar
Yes you need it
thanks for the help
Old Nov 11, 2009 | 01:30 PM
RockmanX's Avatar
thanks for the help
aniel just answered your question yes you need it. I think if your not going to build the longblock then get a fp red 80mm ported and rock that turn boost up as high as it can get safely and rock that. you can get 500+whp out a red just have to have to right flavor of parts is all
Old Nov 11, 2009 | 01:37 PM
Aniel's Avatar
Regarding oil pan issues i would start worrying about that when you start pulling 1.3-1.4 60 foot times at the track then maybe you could suck up a little bit of air.
Old Nov 11, 2009 | 01:40 PM
RockmanX's Avatar
you been pmed back aniel
Old Nov 11, 2009 | 03:41 PM
2highpsi's Avatar
Dude, listen to Aniel. Get the Black. I owned a Red and it was a great turbo but I promise you WILL want more. It's not a matter of if, it's a matter of when. You will be better off in the long run getting the black now. If not I'll keep my eyes peeled for your fp red for sale ad next fall.
