Alternator help needed!
Old Nov 12, 2009 | 07:54 PM
jorgecuatro's Avatar
I just replaced my alternator but found my connector was cracked so i got a connector, wired in and here we are with an issue.
Connector is gray and has light blue removable piece insde by pins but will not snap into alternator UNLESS i remove the blue piece inside.
Alternator is charging at 11.9volts and once idling for a for minutes i can barely run any lectronics, lights, radio etc.
Turn off car and click click. no start. check battery and shes drained down.
charge up and test charging system and i am holding steady at 11.9v
I know battery is borderline but if charging system is not up to par with voltage i want to fix that before i buy a battery.
i dont know where else to go with this. Possible i got a bad alternator from Mitsu? I amstumped and my electrical buddy at mitsu has been sick and turned off his cell on me.
Old Nov 12, 2009 | 08:39 PM
MajorGunHo's Avatar
Well just take the alternator to like o'reilys, they do free inspections to see if they're working. Might be an easy way to narrow it down.
Old Nov 12, 2009 | 08:48 PM
when i test it it shows 11.9 volts. i dont need to take it anywhere else
Old Nov 12, 2009 | 09:03 PM
EvoRob22's Avatar
Sounds like the pins in the connector aren't lining up. An alternator is an electro-magnet. It needs power to work. You have 0 alternator output if your only getting 11.9 volts and thats what your battery is at. Make sure you got the right connector end on. Compare the old one to the new one.
Old Nov 13, 2009 | 05:11 PM
they are correct, striaght, identical unless something in harness is messed up. that of which i have and can change out but will have to splice connector back onto that harness
Old Nov 26, 2009 | 06:26 PM
possible that alternator spiked and fried pcm. my TUNED pcm
Old Nov 26, 2009 | 06:36 PM
SPOOLEDTSiAWD's Avatar
is the wire that connects the battery (I think thats the wire) connected to the alternator?
Old Nov 26, 2009 | 06:43 PM
haha yes.
R/TErnie
190
May 22, 2026 07:59 AM
overdrive1
Jun 1, 2022 08:54 AM
WillieD Evo X
10
Jul 5, 2016 02:09 PM
403evo
23
Dec 16, 2015 04:41 PM
wickdaddy
Lancer How Tos / Installations
Aug 14, 2007 06:40 AM
