Precision 880cc Inj. How much whp?
Subscribe
Nov 15, 2009 | 06:37 AM
I was wondering what the max wheel horse power on say a Dynojet are for the 880s? I bought an Evo with them already installed and a double pumper with twin 255hp walbros. I have the turbo to make over 600whp but wanted to make sure the injectors are up to it...if not what do they MAX out at?
Thanks!
Reply 0
Nov 15, 2009 | 06:59 AM
You can make over 600 hp on 880cc injectors just depends what fuel you wanna run. My buddy evo made 680ish on race gas with 880's
Reply 0
Nov 15, 2009 | 07:16 AM
Out of my own curiosity, are 880's even capable of out-flowing a single Walbro 255HP?
Reply 0
Nov 15, 2009 | 07:51 AM
I use this forumla to estimate hp for injectors. 2/3*inj cc rating on gas and 1/2* inj cc rating on e85. So 880s are good for 586whp MAX on gas and 440whp on e85 on a dynojet.
Reply 0
Nov 15, 2009 | 08:00 AM
Quote: You can make over 600 hp on 880cc injectors just depends what fuel you wanna run. My buddy evo made 680ish on race gas with 880's
Yes on c16 fuel and double pumper.
Reply 0
Nov 15, 2009 | 05:17 PM
From Daves site
This is the newest addition to our line up of fueling options for the Evolution. This is a TRUE drop in setup and it is all done while retaining the stock fuel lines and sending unit. No modification is needed to run this. This setup is the similar to the one used on David Buschur's 9sec. daily driven Evo RS. His RS is making over 650whp on our Mustang Dyno and at this power level as well as some even lower we found out this setup was definately needed.
Reply 0
Nov 16, 2009 | 03:43 PM
Im confused as to what this refers to?
Reply 0
Nov 17, 2009 | 04:51 AM
Quote: Im confused as to what this refers to?
DB's double pumper
Reply 0
Nov 17, 2009 | 04:54 AM
Depends on your fuel setup i.e. e85, c16, q16, 93
Reply 0
Nov 17, 2009 | 05:20 AM
Quote: Yes on c16 fuel and double pumper.
This
Reply 0
Nov 17, 2009 | 05:22 AM
Quote: DB's double pumper
Yeah no question about the double pumper, what we need to know is how much whp the 880s can get me. Thanks
Reply 0
Nov 17, 2009 | 11:31 AM
So, you will be running Volatile Products C 16, and you want to know whether the 880cc injectors and the BR Double Pumper are good for over 600 Dynojet WHP?
Reply 0
Nov 17, 2009 | 12:00 PM
880s max out on a DJ with a single 255 around 540hp on pump! 880s will not max out a single 255, however if you have your fuel reg bumbed, two pumps, large fuel rail you may be able to get close to 570-580 on pump you just need to watch your fuel pressure at high rpms and your duty cycle... You may be able to break 600 on C16 and Q16 but at this point the 880s are just holding you back. If you want to make 600+ you should really have IDC1000 for pump or race gas. If you are running E85 then you will need 1500s
Or you can keep you 880s throw on a Meth kit with a 1500cc meth fogger like I am and push the car into the 600hp range easy Run Q16 through your 880s and then 100% meth through the 1500cc fogger. You will be very happy with your car making over 650 Not to mention if you are running Q16w/1500cc of meth, you will be blowing mad flames out the exhaust!
Mikey
Reply 0
Subscribe
