Dynoflash: Can it raise the idle?
Old Oct 23, 2003 | 03:43 PM
loudogz's Avatar
Can dynoflash adjust the rpm at idle? I'm asking cuz I keep on raising the my idle to prevent stalling but It keeps on going back to the normal idle.....
Thanks in advance!
Old Oct 23, 2003 | 03:49 PM
Evo11V's Avatar
Veteran: Army
ok why is it stalling first of all... might be an issue for the dealer
Old Oct 23, 2003 | 04:07 PM
loudogz's Avatar
I wish I knew the reason why....., I started having this problem when I had SAFC and UR turboback exhaust installed....
I have way too many mods to bring it to the dealer.... Anyway, my problem is that my car would stall once in a while when I go stop and go driving.... escpecialy when the AC is on..... It'd still stall even when AC is off....AC just makes it worst... It also happens a lot when I back out of a parking spot, while turning the steering wheel at the same time.... If I back out without turning the wheel, car seems to be fine.....
PS: It's not my driving .... I have witnesses.... I had people drive my car, and the same thing happens to them...
I checked all my vacuum lines, they seem to be fine...
Old Oct 23, 2003 | 05:23 PM
Crazy4Cars's Avatar
The correct way to fix it is with the Mitsubishi Scan Tool called Mut2, if you don't do it that way, the ecu will keep on doing what is doing.
Old Oct 23, 2003 | 08:12 PM
DynoFlash's Avatar
Did you also do a bov?
We could prob try and re-tune your idle - but it sounds like you have hardwear related issues
Old Oct 23, 2003 | 08:16 PM
Guru's Avatar
THe power FC can adjust idle.
Old Oct 23, 2003 | 08:51 PM
BigBoogieman's Avatar
Don't you suspect the SAFC installation or settings?
Old Oct 24, 2003 | 05:41 AM
loudogz's Avatar
No, I never changed it to bov!, I still have the stock diverter valve in there....
Oh yeah, AL do you have anytime for me....today... Friday?
