My custom catch tank with pcv breather (photos)
The kiw was actually meant for a B series honda motor but with a little bit of imagination everything went well!
The only problem i have in order to take advantage the PCV breather fully is to actually remove the PCV valve and replace it with a straight through barb fitting, which i cannot find anywhere!
I think Buschur has it and he offers it for his breather kit. I will call Monday and confirm and order...
Apologies for the crappy pictures but i only had the iPhone handy...
Keeps it from smoking like a SOB.
Very few crankcase vents manage to pull any kind of a vacuum without sucking oil out of the motor and either blowing it into the exhaust or turbo inlet, depending on method used of course.
is that a morso ? and as far as that barb fitting try b&r fittings on honda-tech.com the guy is a sponsor he makes his own cans and should have any fitting you need.
Yes it is a moroso.
Thanks for the tip. I will try and see if they have it.
In the future I might change the fittings and modify the valve cover to have big -8 AN or even -10 AN fittings.
kouzman
Jan 31, 2010 05:46 AM
kouzman
38
Mar 6, 2008 07:34 PM
