Well it happened again.. i just have no luck
Originally posted by AvatarOfWar
Sorry to hear about it man; those of us who test these cars are going to keep breaking things. Pay no attention to the brand loyalists, the Exedy is a kick-*** unit - but it does take a competent person to install properly.
At least your MPH is consistent
damn you busted up two exedy clutches, i am still trying to bust my stock, damn thing is still holding up, after so much abuse.
i would def. call the company see if they will hook you up with another, these big companys will not want bad advertisment of thier prouducts espesially on this site, which the majority of evo owners read.
good luck
good luck
DO NOT LET THE CLUTH OUT SLOWLY AT HIGH RPM
you guys are not driving your cars right. Do not listen to the idiot that said, "slip your clutch out slow". That burns the hell out of your clutch. Take it from me, i installed my own clutch on MY EVO.
CarPhoto: actually i do know how to drive my car.... my clucthes never burnt or made anytime of smell except for my stock one wich just blew out...
And i bought another exedy clutch b/c it was the only one i could find in stock...
the GD Max set-up is the one im talking about. The GD pro is a non-sprung hub design-not streetable. The only downside to any twin-disc setup is the clutch chatter/noise that they make when the clutch is depressed or when decelarating, but you grow used to it.
Originally posted by superz
this has nothing to do with brand loyalist, the truth is that if you were to look at the stronger and more efficient design of the HKS throw out bearing clip/retainer you can see its far superior. I dont think you've had both clutches in your hand and compared, I have. Not too many people actually know how these clutches work or how they are different than the average clutch. While the Exedy is by no means a ****ty clutch it has its flaws. It grabs much more violently than the HKS even though they both share the same clutch material, and they both support the same hp/torque levels. This is only my personal experience.
Did you have both of those clutches in your Evo? If not, I don't know how you can be so critical of the Exedy. Mine isn't grabby at all - maybe the single plates are, but the twin is awesome for daily driving. It's one of the most forgiving clutches I've driven.
The only flaw I would mention about the Exedy (coming from experience) is that it makes more noise than some people are comfortable with. I don't know what you mean by violently. As it has been said, you can break any quality part if it's not installed or used properly (and if I know Rollaway, it was used properly
Keith
Superz,
Superz,
Twin, by the way. But to each its own.
