Clutch noise downshifting
Old Oct 24, 2003 | 08:55 AM
VanillaEps's Avatar
I recently took a 300 mile trip to Albany, NY from Long Island. I noticed that once in a while, while I was downshifting to go through some tolls, I heard a sort of grinding/'farting' noise everytime I let go of the clutch while downshifting from 5th to 4th and 4th to 3rd. It does not happen while downshifting from 3rd to 2nd.
Have any of you experienced this? It's almost time for my 5k appointment, so I'll have the dealer check it out, but if anyone knows what this is - it might be helpful in trying to diagnose it.
Thanks!
Old Oct 24, 2003 | 11:44 AM
berkel's Avatar
Do a search for decel noise...
Some percentage of EVO8s have it, AFAIK there is no real "fix," but changing drivetrain to synthetic fluids seemed to help me a little.
Good luck,
FB
Old Oct 24, 2003 | 03:57 PM
VanillaEps's Avatar
I know all about the deceleration noise. It's like a loud chatter coming from the engine while you are coasting from a stop. What I am alluding to is a sort of grind/moan from the clutch area when I downshift. I even feel the vibration on the pedal.
Old Oct 24, 2003 | 06:54 PM
evoracerx's Avatar
I had this problem. As I would let out the clutch for a downshift I would get a loud humming noise until the clutch was fully engaged. The cause was weak fingers I believe. There were hotspots on the half of the flywheel and pressure plate. Clutch worked fine and there was no abnormal wear (7000 miles), just a really annoying noise. Mitsubishi engineer looked at it and warrentied it. But if they take apart your transmission and find your clutch melted form launching it, then your screwed. PM me and I will tell you where I got this warrentied.
Old Oct 24, 2003 | 07:42 PM
MYEVOVIII's Avatar
Search for decel noise
Old Dec 22, 2003 | 06:42 AM
AutoXer's Avatar
I just recently started getting this exact same noise. It is NOT the decel noise. It only happens while the clutch is engaging(taking foot off of clutch pedal). It has 11,750 miles on the Odo. Everythings works fine, but it's very annoying. If it continues to be a problem I will take it in to have the Mitsu guys take a look at it.
Old Dec 22, 2003 | 06:49 AM
nastea's Avatar
are you up-shifting or down-shifting?
the decel noise is just vibration of the disc, try driving a twin disc, its noisy......
Old Feb 4, 2004 | 04:31 PM
Blair Doherty's Avatar
It is a faulty pressure plate. Mine started the noise at 4000 miles and finally after 4 trips to the dealer and at 9000 miles with still no clutch slippage the dealer fixed it under warranty.
Old Feb 4, 2004 | 04:33 PM
It is a faulty pressure plate. Mine started thae noise at 4000 miles and finally after 4 trips to the dealer and at 9000 miles with still no clutch slippage the dealer fixed it under warranty
pb91
Jun 8, 2011 02:44 PM
imstig
Lancer Tranny/Drivetrain Tech
24
Apr 20, 2009 05:01 AM
Matt-Helm
Nov 25, 2005 07:03 AM
6one9EVO
Sep 22, 2004 03:40 PM
jeddi
Aug 12, 2004 02:32 AM
