Forced Performance Turbos - Compressor Cover Leak Notice
Old Nov 29, 2009 | 07:00 AM
CMB's Avatar
CMB
I have to guess this would be true of all the turbo makes as well in these sizes?
Old Nov 29, 2009 | 07:48 AM
CO_VR4's Avatar
The two turbos that Ted B. has identified are Garrett based turbos, not Mitsubishi based turbos.
His observations on two Garrett turbos would not translate into assumptions about Greens, Reds, or Blacks, and may not translate into conclusions about Garretts, either.
It never hurts to check any part carefully before you put it on the car, though.
Old Nov 29, 2009 | 09:51 AM
EvoDan2004's Avatar
i had this on my reg 35r ted. it leaked right where the cover met the base. pretty badly too. i just took some orange rtv and sealed it up.
the new turbo does not seem to do this so i never bothered.
Old Nov 29, 2009 | 10:02 AM
E85evo8's Avatar
I just boost leak tested my HTA 3582r up to 20psi and no leak from the compressor cover...I guess I will turn the boost up to 25-30psi and see if I get a leak from where Ted B. has posted about. If I do then I will post up here as well. My HTA 3582r does not have an o-ring sealing the compressor cover to the backplate...thx for the heads up!
Old Nov 29, 2009 | 10:29 AM
rd122481's Avatar
Anybody have pics of this area?
I have a brand new HTA3582 that I'm waiting to install & would like to do this. Thanks!!
Old Nov 29, 2009 | 10:58 AM
E85evo8's Avatar
detailed pics would be nice...
Old Nov 29, 2009 | 11:00 AM
Ted B's Avatar
I will try to provide pics when I get the compressor cover off. In my particular situation, that looks to require the entire turbo to be removed.
I am not in a good mood right now.
Old Nov 29, 2009 | 11:18 AM
riceball777's Avatar
pics would help a lot
thanks
Old Nov 29, 2009 | 12:23 PM
cij911's Avatar
Ted - You sure have had to fix a number of problems with your setup (sorry). I guess one of the nice things of an OEM setup is that the reliability, QC, tolerances, and product robustness are much better than aftermarket. The trade-offs between power and reliability / streetability I guess.....
Old Nov 29, 2009 | 08:47 PM
Ted B's Avatar
Most of the issues that have plagued me are due to aftermarket parts that aren't doing what they're supposed to do.
Anyway, here are a few pics:
BEFORE you remove the compressor cover, get a Sharpie and put a couple alignment marks so you won't cry later (see them at the screw holes) because you misaligned it. The dark residue is epoxy that I used in a vain attempt to seal the leak without removing the turbo. Don't try it. Sealing one area just forces the leak to a different area.
When you peel apart the compressor housing, you see a step machined around the periphery of the center section.
That step mates with the groove machined around the periphery of the compressor cover.
The problem with this is it did not create a proper seal in my car or Drifto's car. Another issue is that since there is no step machined at the edge of the intake barrel on the compressor cover, it is difficult to perform a pressure test above 20 psi. I can get about 25 psi if I double the clamps, but getting it to hold more pressure requires hair spray, skateboard tape, etc.
Anyway, the fix is to apply a bead of gasket sealer around the mating edge of the compressor cover as shown here.
I'll pressure test it tomorrow (24 hr curing time), but that should do it.
Old Nov 30, 2009 | 06:32 AM
FathouseFab's Avatar
I don't use rear that much rtv bro, just a small bit in the corner will do.
Here is a pic of the o-ring for referance.
Fathouse
Old Nov 30, 2009 | 06:37 AM
TiALSport's Avatar
Garrett turbos all have some leak at that location, they have an 'acceptable' tolerance level from the factory...the housing is a Garrett housing and the backplate is a Garrett backplate - it's nothing FP would have done
Old Nov 30, 2009 | 06:46 AM
Ted B's Avatar
FWIW, I wipe the bead before I sandwich the covers back together.
As far as the leak itself, let me clarify something. I'm cannot claim this to be unique to FP turbos, as I would expect that it would be a possibility with any cover that uses a 'seal' of similar design. In this instance, the first time I've encountered this were coincidentally with two FP turbos. IF this is a result of a design modification from Garrett, then let everyone who buys a newer Garrett be advised accordingly.
More importantly, what I am advising is that anyone who buys a turbo, from whatever source, where this sort of arrangement is used, would be for the wiser to address it before it could become a problem as it did in my case.
Old Nov 30, 2009 | 07:55 AM
Craig King's Avatar
I am curious to see FP's response to this issue.
Old Nov 30, 2009 | 08:52 AM
CO_VR4's Avatar
I don't expect it would be much different than TIAL's response. It's an issue related to the mating aspects of two GARRETT parts, not modified by FP.
The issue would be the same for anyone who sold a stock GARRETT turbo, or a modified GARRETT turbo in which those two parts were not changed.
