FIC 2150cc?
Old Nov 30, 2009 | 11:39 PM
omniprobe's Avatar
FIC 2150cc?
I havent heard much about them. Anyone using them? Same thing as the ID2000's?
Old Dec 1, 2009 | 09:07 AM
Steve93Talon's Avatar
They're both derived from the same Bosch injector. From what I've read, the FIC version fits DSMs and EVOs better. Flow should be identical, the only difference is that ID supposedly dynamically balances them so that the latencies are matched within a set. FIC's counter-arguement is that this is a very well R&D'ed injector and that they're extremely well matched from the factory already. Everyone I've seen running them seems to be very satisfied with them.
Old Dec 1, 2009 | 10:24 AM
maperformance's Avatar
We are running them in a car here at MAP and we should have some results this week.
Old Dec 1, 2009 | 11:07 AM
Colt4g63's Avatar
Interested in seeing what you guys think about them. I have the Blue Max 1450s right now and have them maxed out with more boost left on the table... So i need to get another set of injectors sometime soon. That and ive heard these injectors run so much smoother and it gets rid of the ruff spot at 2500RPM area on AEM cars as well.
Old Dec 1, 2009 | 11:13 AM
Force-Fed Performance's Avatar
interested to see the results as well. May be looking to use these on our shop car instead of the ID injectors on a haltech
Old Dec 1, 2009 | 11:25 AM
Joshs EVO's Avatar
I have 8 of the blue max injectors. 1550cc and 1850 on my dual rail Magnus V5 setup. I had maxed out my last set or precisions pretty quickly with my 4088 so once I get this on we shall see what she can do since i have 3400cc of E85.
Old Dec 1, 2009 | 11:29 AM
norcalSRTrida's Avatar
Are these High Imp.?
price?
EDIT: NVM. checked MAP's site.
running FIC's 1150's right now, and have no issues with them, but not needing a driver/resistor box appeals to me, and i heard these 2150s and the ID2000's idle/cruise great on any car/hp...
Old Dec 1, 2009 | 11:31 AM
KevinD's Avatar
good god! 3400cc per cylinder? are you making 1500whp? our 1450's are fine at 600whp (on e85).
Old Dec 1, 2009 | 03:35 PM
Creamo3's Avatar
Agreed, that sounds a bit overkill
Old Dec 1, 2009 | 03:50 PM
WAY overkill lol
Old Dec 1, 2009 | 04:50 PM
Joshs EVO's Avatar
It's not actually overkill. I will max the 1550cc before that. Also don't forget where I live. Colorado at 5500+ feet. I had already maxed out the 1650cc precision at 33 lbs and with a new IC that will drop the boost, a new UICP and a BOV the 1550 won't be enough for 45-50 psi.
Old Dec 1, 2009 | 04:52 PM
yes but you would be fine with like 1200s on both rails or even 1450's on both
Either way, you wont run outta fuel now lol.. good stuff man bet she will do some ncie things now
Old Dec 1, 2009 | 05:40 PM
Joshs EVO's Avatar
better to have more than less. sides i got a killer deal on all of it.
Old Dec 1, 2009 | 06:19 PM
Driven Innovations's Avatar
Josh all you really needed is to put back your stock injectors and use them as primarys and use the other 1650s in the secondary rail.
Old Dec 1, 2009 | 06:25 PM
^^ what tom said, you get my PM and Email Tom?
