HKS 272's or GSC2's on a stock setup?
Agreed that GSC2's make more power..but what about the drive ability and the fact that I use it as a daily car? Because even on the GSC's website it says that S2's are for larger tubo's...and there the fuel factor then, because the maximum available fuel we have available here is 91 octane.
I think I will go with HKS, just a more sensible decision. Does any1 agree?
Mikey
S2's.great. Hks great. Kelfords Great. The amount of power based on how good your tuner is.... goodluck
You can always go with Kelford 272 they are between the HKS 280 and the S2. I have them on an Evo 8 and they are aggresive (lumpy) at idle but have very good street maners. No stalling on my car even with the A/C on. And I tuned them myself.
The new S2s are 274/274 11.2mm lift/11mm lift
Mikey
Ah ok I was looking at some posts and it seemed like there was two versions of the S2 a 278/274 and a 274/274. I'll call up GSC tomarrow and order me some S2s either way. Thanks for the response blkcarbonevo.
i regretted putting in my kelford 272's almost instantly. they are bad on low HP cars (i.e. below 400whp). If you want response, dont go Kelford 272's. If what people say is right, the S2's are similar. i think you'll lose alot of response out of these cams.
Not just spool, but transient response. Actual Lag will increase.
If you're ok with that, then go nuts.
Just FYI, as noone told me this before i bought my pair.
a true statement on the under 400hp cars and kelfords comment, except most cars with kelfords make 400whp+ even bolt on ixs we tune with kelfords and stock turbos make 400hp. Kelford 272s have one of the broadest powerbands of any cam on the market. Im sorry you are unhappy with the kelfords but we have installed and tuned just about every cam in the market and they have about the best powerband of any cam we use.
how do you stop them lagging? even with a stock turbo the lag was great.
Not just actual spool point, but even well into the powerband (5000rpm etc with stock turbo) when you floor it, the lag is greater than standard cams.
hmm thats very very weird, what ecu is the car tuned on? could have a ton to do with tuning man. We have never seen anything but faster spool with these cams on any setup. Dont even worry about going with a mivec head if you are building a stroker get a good set of cam gears and degree the motor properly and she will be just fine. Mivec is a very good tool to use especially during tuning but at some point with high hp big turbo cars it is not beneficial
so i guess HKS 272 cams are for people running a little over stockish? because right now i have a gt30 turbo and running some hks 272 i find them to be very good...maintained good power...but haven't tried any other cams...
